Squeaky clutch.... SQUEEEEEK
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dnlskier, Feb 7, 2017.
  1. Mar 5, 2018 at 8:24 AM
    JonWon
    JonWon Well-Known Member
    AZ
    2017 DCSB OR 4x4
    ya the squeak, almost groaning sort of noise and you can definitely hear it in the cab...everyone in cab can hear it lol
    I thought it would just be the squeak that got fixed but the new clutch arm is actually shaped differently so it changes the whole shifting experience...its a different part not just different better grease. Like Malibu said the clutch is smooth now...no noise no gritty feeling. I almost felt like I used to nurse the clutch and gas pedal couldn't just easily throw it into the next gear.
  2. Mar 5, 2018 at 8:25 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Not sure if I buy into the super secret grease thing as would that not be what is used when the truck goes down the assembly line? This has been a continuing problem since 2005 when the plastic pedals came out.
  3. Mar 5, 2018 at 8:31 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Valid point...he really put a TON of that grease on there so maybe that's why mine has stayed so quiet.
    Comparing that grease to the disk brake grease it is nothing similar. The white grease on there from the factory is much harder and more "flaky" than oily.
    shakerhood[QUOTED] likes this.
  4. Mar 5, 2018 at 8:36 AM
    shakerhood
    Southern Ohio
    That's awesome that it has stayed quiet, the end result is all that matters!
  5. Mar 5, 2018 at 8:36 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’ve always really disliked the clutch and the way the trans shifts on this truck. The only ways I’ve found to upshift without crunching the gears is to either shift at the absolute perfect rpm, shift super fast while starting the gear change slightly before disengaging the clutch, trying to rev match - which is a pita with the drive by wire, or reaching over my lap and shifting with my left hand. Downshifting is damn near impossible sometimes. Maybe this is the fix.
    Jab969 likes this.
  6. Mar 5, 2018 at 8:41 AM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Damn the things you mention almost sound like you are experiencing the stuck in gear problem..is it ever extremely hard to get out of 6th?
    Yes I would say try and get this done...my clutch and shifting are super smooth now no lies like I'm amazed in the difference and this is how it should have felt off the lot a year ago.
  7. Mar 5, 2018 at 8:44 AM
    Rujack
    Yep, I had the tsb for the detent done a while back.
    I wonder if the syncro problem in these transmissions is due to this problem.
  8. Mar 5, 2018 at 9:39 AM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Interesting...so I also had the detent ball replaced which fixed the stuck in gear. Weird on this TSB its actually been the same TSB since 2005 so why they didn't start with these parts in the 3rd gens who knows...the TSB is 0186-12 had to call Bell Toyota to get the #.
  9. Mar 5, 2018 at 9:41 AM
    Rujack
    Is that the number for the clutch pedal fix, or detent?
  10. Mar 5, 2018 at 9:45 AM
    JonWon
    AZ
    2017 DCSB OR 4x4
    That is for the clutch pedal squeak :)
  11. Mar 5, 2018 at 10:00 AM
    Rujack
    Nice, thx for the info!
  12. Mar 5, 2018 at 10:02 AM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Sure thing! :)
  13. Mar 12, 2018 at 4:31 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Thanks for this, my clutch pedal was fine until about 21,500mi, now it feels like it’s shifting around under my foot. Not squeaky but makes a little bit of noise sometimes.
    Today I took a look, the whole pedal and arm thing has quite a bit of side to side play. Gonna have them look at it at 25k service.
  14. Mar 14, 2018 at 4:16 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Sure thing hope they get ya all fixed
  15. Apr 27, 2018 at 7:20 AM
    #35
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    Mine just started on the drive from benning to bliss.
  16. Apr 27, 2018 at 7:29 AM
    #36
    su.b.rat
    su.b.rat broken truck
    grease it up
    shakerhood likes this.
  17. Jun 6, 2018 at 6:40 PM
    #37
    VolFan57
    VolFan57 Well-Known Member
    TENNESSEE
    2016 TRD OR 4x4 - MGM - traded. 2018 TRD Sport BRM 6MT
    I just had my clutch pedal assembly replaced today. After my 2018 hit 4,000 miles I experienced the creaking clutch. Dealer was good and performed the TBS without any hassle....very pleased with the outcome.
  18. Apr 9, 2019 at 6:33 AM
    #38
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Saw this thread is being posted in again. I sold my manual 2010 and have a manual 2018 now.
    For the 2010 I started using Sylglide disk brake grease (after reading about it on TW) and it worked better and more long term than the graphite.
  19. Apr 9, 2019 at 8:42 AM
    #39
    Shellshock
    Iowa
    My 2017 squeaks too. Greased it up and its been fine since.
  20. Apr 9, 2019 at 8:49 AM
    #40
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Grease it up with sylglide and DO NOT take it to the dealer. Most of them have no clue with clutches these days and will get everything wrong after they take it apart. Been there done that.
    My TSB "fix" started squeaking again after a few days. I felt like an idiot for having my shit torn apart for nothing. In the end, I took it apart again and gresed and assembled it properly.
    Grease is the answer.
    Also, I bought a tub of that "super special space grease" that toyota lists on the tsb. $50
    I used ALOT of it and here I am with minor squeaking some months later. The sylglide works better according to alot of peeps.
    rubiconjp and tonered like this.
