Squeaky Clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by nicnicman, Jun 18, 2011.
  1. Jun 18, 2011 at 8:09 AM
    nicnicman
    nicnicman [OP] Active Member
    Maine
    03 Tacoma SR5 4 Cyl Manual
    I've recently started experiencing the dreaded clutch squeak in my 2003 Tacoma SR5 2.7L. I've seen a lot of info online for this issue, from replacing a u-bushing on the torsion spring to replacing the entire torsion spring with a simple spring from a hardware store. However, all these solutions seem to apply to 6 cylinders. With the four cylinders I have heard that you should replace the entire clutch assembly.
    I took it to a mechanic and he greased the fork but it did not solve the issue at all. He said it was nothing to worry about but it's making an otherwise nice truck sound awful.
    Does anyone have any knowledge or experience with this issue? If so, what should I do about it? The squeak can not be ignored and it's starting to drive me crazy.
  2. Jun 18, 2011 at 8:12 AM
    Madjik_Man
    Colorado Front Range
    Learn to ignore it.
    Roughly around the 10th year of ownership your brain will automatically tune out the noise.
    So has been my experience :)
  3. Jun 18, 2011 at 8:47 AM
    nicnicman
    Maine
    Not really what I wanted to hear. I just bought the truck a month ago! It didn't have the squeak when I bought it.
    There has to be a way to fix this!
  4. Jun 18, 2011 at 9:04 AM
    Madjik_Man
    I have the 3.4 V6 and if I spray some lube on the bushing and spring the squeak goes away for a month or so.
    Fortunately for me the noise really only acts up when it's super cold and/or humid... living Colorado helps keep the squeaking at bay most of the year.
  5. Jun 18, 2011 at 9:05 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    So is your clutch peddle assy. that much different than a 6 cyl? Can you take a picture of it?
  6. Jun 18, 2011 at 9:26 AM
    nicnicman
    Maine
    Mine does not appear to have a torsion spring. And the creak sounds like it may be coming from the engine compartment. But I can still hear it loud and clear in the cab. I'll go take some pics.
  7. Jun 18, 2011 at 9:45 AM
    nicnicman
    Maine
    Here are some pics. It was tough to get a good shot so here's a bunch of them. Notice the black spring and lack of torsion spring. I'm not sure if this is typical of the 4 cylinders or if this one has had the "spring mod" done to it.
  8. Jun 18, 2011 at 9:53 AM
    nicnicman
    Maine
  9. Jun 18, 2011 at 11:20 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Well your right that looks nothing like mine in my V6. But the problem still sounds the same, A metal on metal sound so I would inspect all of your moving parts in that assy and make sure that there is nothing rubbing. Sorry I couldn't help anymore.
  10. Jun 18, 2011 at 11:32 AM
    nicnicman
    Maine
    Thanks for the suggestions. I'll give the assembly a close inspection. However, I think the sound might be coming from the engine compartment. What would I look at inside the engine compartment. I can see the master cylinder but I'm not sure where the fork or boot is. I just got a repair manual so I'll take a look.
    If anyone has more specific advice please let me know. Thanks.
  11. Jun 18, 2011 at 11:35 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    You should be able to see the clutch fork sticking out from the side of the tranny right below your master cylinder maybe double check the linkage that connects that to your peddle assy.
  12. Jun 18, 2011 at 11:47 AM
    nicnicman
    Maine
    Okay, I'll take a look. Thanks again.
  13. Jun 18, 2011 at 3:37 PM
    nicnicman
    Maine
    If anyone else has any suggestions I'm all ears.
  14. Jun 19, 2011 at 4:45 AM
    nicnicman
    Maine
    I think it's coming from outside, but I'll need to get someone to push the clutch for me while I listen to confirm. My truck model does not appear to have come with a torsion spring, just a standard spring as shown in my pictures, so it can't be the bushing.
    Thanks for the post. I'll try to isolate the squeak. If anyone has solved the squeaking issue with my particular model please let me know. I have heard I should try some lithium grease in a grease gun and shoot into the bell housing. So maybe I'll try that.
    I wish I could live with the sound, but its pretty loud and embarassing.
  15. Jun 19, 2011 at 6:30 PM
    JBSTRD
    JBSTRD Chicks Dig Body Damage
    Washougal, WA
    98 TRD Limited
    Donahoe CO's, OME Dakars w/Extra Leaf, 33" BFG KM2's, Warn 9.5XP, ARB Bullbar, AllPro Rear Bumper, Budbuilt Skid/Belly, Safari Snorkel
    The noise is your clutch fork inside the bell housing. I have a Tacoma and 3rd Gen 4Runner. My truck used to make the sound until I had the clutch replaced, but my 4Runner still makes the noise. I just shoot lithium grease or WD40 in there every once in a while and it keeps the noise down. There is no reason to replace the clutch until it actually goes out unless you absolutely can't stand the noise.
  16. Jun 19, 2011 at 6:33 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    Sorry to thread jack But i like your truck man! Kinda resembles mine:cool:
  17. Jun 19, 2011 at 8:33 PM
    nicnicman
    Maine
    Okay I'll give it a shot.
  18. Jun 20, 2011 at 4:36 PM
    nicnicman
    Maine
    I went under the truck and sprayed some lithium in the bell housing and the squeaking has lessened a lot. Thanks for all the suggestions everyone.
  19. Jun 21, 2011 at 12:38 AM
    JBSTRD
    Washougal, WA
    98 TRD Limited
    Thanks!!
