Squeaky Coilovers
Discussion in 'ICON Vehicle Dynamics' started by Markc1024, Oct 10, 2016.
  1. Oct 10, 2016 at 6:27 AM
    Markc1024
    Markc1024 [OP] Well-Known Member
    Just got my Stage II installed. One day after completion, the fronts started to squeak pretty bad - any movement would cause it. I read some comments online that lubing the shafts is a good first step. I did rub some good quality bicycle chain lube (ProLink) on the shafts and that took care of it. However, I'm concerned if this will be an ongoing problem/maintenance item that I'll have to stay on top of?
  2. Oct 13, 2016 at 9:11 PM
    Markc1024
    Washed the truck and the squeaks returned. Looks like I'll have to lube my shafts after every wash - this sucks! Can't get a reply from Icon here or via their email.
  3. Nov 3, 2016 at 5:48 AM
    Markc1024
    Hit the carwash again and it seems the need for lube is starting to subside. No squeaks right afterward, but I hit them again with some lube with the intent to help the seals break-in further. Icon did eventually let me know via email that these can squeak when new, but no real advice on how to avoid the problem besides lube. Would be nice if they would document a break-in procedure or at least what to expect with new shocks. Seems they are still a no-show on TW.
  4. Nov 3, 2016 at 5:51 AM
    Large
    Large Red
    What are you lubing exactly? The shock shaft? I don't think I've heard of a shaft making squeaks. 99% of the time it's the rear leafs or a uniball in your UCAs - but you don't have uniball uppers. Some videos would help.
  5. Nov 3, 2016 at 9:23 PM
    Markc1024
    Yes, the shaft and seal. That is the source
  6. Nov 17, 2016 at 6:20 AM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I have had the same issue on multiple icons. Sometimes flexing them out on a rutted dirt road takes care of the squeek, other times i lube the shaft. Habent seen the squeek lead to any leaks or issues.
  7. May 16, 2019 at 11:35 PM
    NurseMurseJon
    NurseMurseJon New Member
    White 2018 Toyota Tacoma 4WD
    New to the site but a long time Tacoma lover. After the install and up to this time, are you happy with the stage II? I am looking at doing a similar route with my 2018.
