Squeaky Dakar Leaf Springs
Discussion in 'Suspension' started by Ostate09, May 22, 2010.
  1. May 22, 2010 at 9:15 PM
    Ostate09
    Ostate09 [OP] Member
    Houston
    09 4x4 DCLB
    I recently installed the full OME lift with Dakar leaf springs. The rear end seems to squeak all the time. The people that installed the lift said it just needed to be broken in. Any ideas on why they are so noisy?
  2. May 22, 2010 at 9:17 PM
    Ostate09
    Houston
    09 4x4 DCLB
    Just realized this probably belongs in the suspension section. Sorry about that.
  3. May 22, 2010 at 9:21 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    probably dirt/mud in the springs. need to be hosed out and spray some lube on them
  4. May 23, 2010 at 7:55 AM
    Ostate09
    Houston
    09 4x4 DCLB
    The spring are brand new so I don't think they are dirty. What lube would you suggest using?
  5. May 23, 2010 at 2:39 PM
    jhodge83
    SC
    17 XLT Sport
    i usually spray PB blaster in the leaf springs...shuts them up for a while. another thing i heard recently that i didnt think about yesterday was to check the torque on the shackle bolts. too tight and they would cause squeaking. not 100% on the correct torque though...thought it was 95lbs
  6. May 23, 2010 at 2:44 PM
    LoHoNas
    LoHoNas Well-Known Member
    Jeff
    Lake Jackson TX.
    09 4x4 DC TRDSPORT MGM
    Debadged, Fog light mod,Grillcraft, Icons,TC UCA's, OME dakar leaf pack,Procomp 7089,BFG KM2 285/70/17 JVC NAV
    Got the same problem with my dakars. I used a pry bar and got grease in between the leafs but need to do it again cus the noise came back. Im on the beach a lot prob dont help
  7. May 23, 2010 at 7:37 PM
    Ostate09
    Houston
    09 4x4 DCLB
    Can anyone confirm that the torque for the dakar shackle bolts is 95lbs?
  8. May 23, 2010 at 7:40 PM
    jhodge83
    SC
    17 XLT Sport
  9. May 23, 2010 at 7:43 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I took about three hours cleaning and trouble shooting these damn things. Its the bushings that OME send already in the leafs that squeak. I looked it up on TTORA and the consensus is the bushings are to blame. I've gotten to the point where I'm just putting up with it till i can swap in some Toyota bushings.
  10. May 23, 2010 at 8:39 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    What he said ^^^ It's the bushings, Mine squeak from the front and rear bushings. I can get them to stop for a while with a good shot of lube but it comes back after the first day in the dirt. You will get used to it;)
