Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Dec 2, 2014 at 9:47 PM
    #321
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    That's swell
  2. Dec 4, 2014 at 5:36 PM
    #322
    Rocket67
    Rocket67 Well-Known Member
    Newfoundland Canada
    14 DCSB TRD Sport 6SPD MGM
    N-fab w/ IPF 968, TRD cat back, 285 & 265 duratracs, pro comp 7036. leer xl
    My dakars ride great and I used the rubber to solve the squeak that comes from the front area of the pack but I'm now getting a squeak from the bushing on the shackle side. Anyone try those greaseable bolts for squeaking bushings? Thanks
  3. Dec 4, 2014 at 6:33 PM
    #323
    OZ-T
    Peter North
    British Columbia
    On a 2nd gen ? Who makes them ?
  4. Dec 4, 2014 at 10:19 PM
    #324
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
  5. Dec 5, 2014 at 4:10 AM
    #325
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
  6. Dec 5, 2014 at 5:20 AM
    #326
    Rocket67
    Newfoundland Canada
    These would eliminate having to unbolt, pull bushings, and grease every 3 months!
  7. Dec 5, 2014 at 7:43 AM
    #327
    OZ-T
    Peter North
    British Columbia
  8. Dec 5, 2014 at 8:09 AM
    #328
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
  9. Dec 5, 2014 at 8:39 AM
    #329
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Are the dakar bushings a odd size from OEM? Just asking because it seems like new bushings might be in order. I think that mine has some two piece rubber bushings that would be better off with some sort of poly.
  10. Dec 5, 2014 at 8:42 AM
    #330
    OZ-T
    Peter North
    British Columbia
    They are the same size as OEM . You talking fronts or rears ?
  11. Dec 5, 2014 at 8:42 AM
    #331
    OZ-T
    Peter North
    British Columbia
    Yes , nice guy too
  12. Dec 5, 2014 at 9:34 AM
    #332
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    I was thinking about the rear mostly. The front came with a bushing already installed. But also I was wondering about the guy who replaces the shackle and/or bushings. It would be a bad day if the OME eye bushings were a larger od.
    I talked to the guy who makes the greasable bolts and he needed bolt dimensions.
  13. Dec 5, 2014 at 9:35 AM
    #333
    OZ-T
    Peter North
    British Columbia
    Why noy go with the Defined greaseable shackles then ?
  14. Dec 5, 2014 at 9:43 AM
    #334
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I think this is the issue I'm having....
    Once I'm done dialing the front coilovers in etc, I'm going to address this. Let me know what you do/did to remedy this
  15. Dec 5, 2014 at 9:59 AM
    #335
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    I was thinking that we wanted to grease the inside of the bushing. I guess I don't see how those shackles would get grease there.
  16. Dec 5, 2014 at 11:01 AM
    #336
    OZ-T
    Peter North
    British Columbia
    Through the grease nipple
  17. Dec 5, 2014 at 11:31 AM
    #337
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That would grease the inside of the sleeve, not the inside of the bushing.
  18. Dec 5, 2014 at 11:34 AM
    #338
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    You mean that you don't just grease the nipple? DOH! I'll go back in my corner.
    I couldn't tell if the grease path was drilled through the bushing and metal sleeve or just into the shackle. I'm fairly new to this stuff, so I was just asking.
    Oz, you have these right? I couldn't find a price on these, does anyone know what they're going for?
  19. Dec 5, 2014 at 11:57 AM
    #339
    OZ-T
    Peter North
    British Columbia
    Isn't that where the movement / squeak would be though ?
    ie between the bushing sleeve and the through bolt ?
  20. Dec 5, 2014 at 12:01 PM
    #340
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    One of three possible places.
    Can be metal/metal from bolt to sleeve.
    Can be metal/poly from sleeve to bushing.
    Can be poly/metal from bushing to pivot.
    Personally I hate greasable shackles. There's a hole in the bolt...a hole. Give me a grade 8 any day.
