Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Dec 5, 2014 at 12:05 PM
    #341
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    There is no hole in the bolt with the Defined ones :notsure:
  2. Dec 5, 2014 at 12:21 PM
    #342
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Sorry I mean greasable bolt. I hate the greasable bolts.
  3. Dec 5, 2014 at 12:23 PM
    #343
    OZ-T
    Peter North
    British Columbia
    No worries , just making sure we're on the same page
    Do you not think the Defined set up would eliminate the main point of noise / bind the way it is designed ?
  4. Dec 5, 2014 at 12:28 PM
    #344
    TrueNorth
    TrueNorth Well-Known Member
    Maryland
    13' V6 4X4 DCSB
    Weather tech floormats and visors, ImMrYo rear-view mirror bracket Cooper ST Maxx 255/85/16 On stock TRD alloys. OME 887's w/NitroCharger sports, LR uca's, Toytech sway bar relocate, Dakar leaf's modified with some 1/8" UHMW liner strips. SuperBumps front and back.
    A greasable shackle will lube the outside of the bushing, and a greaseable bolt would grease the inside, preferably without the metal sleeve to the grease gets to the bushing??
  5. Dec 5, 2014 at 12:30 PM
    #345
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Of the three "squeak zones" above, it primarily will address the last one. It can help with the middle one depending if there's a gap between the bushings. It won't help at all with the thru bolt/sleeve.
    Regardless, you still have to loosen the bolt before you grease or you risk blowing out the bushing. For the price you pay for those shackles...I'd rather just grease it manually. Also gives you the opportunity to clean out dirt and debris which is the main cause of noise.
  6. Dec 5, 2014 at 12:31 PM
    #346
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Do you know what happens to leaf spring bushings that don't have sleeves? There's a reason they come with sleeves.
  7. Dec 5, 2014 at 12:34 PM
    #347
    OZ-T
    Peter North
    British Columbia
    Don't you need to remove the bushing in order to grease it manually ?
    and what exactly do you mean about loosening the bolt prior to greasing or risk blowing the bushing ? Do you mean to allow for excess grease to escape ?
  8. Dec 5, 2014 at 12:44 PM
    #348
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  9. Dec 5, 2014 at 12:45 PM
    #349
    OZ-T
    Peter North
    British Columbia
    Thanks Jason
  10. Dec 5, 2014 at 12:53 PM
    #350
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    I'm thinking oval... This is what confused me. It's from the website selling the greasable bolts
    "1. You need to replace stock rubber bushings with polyurethane, since petroleum-based grease will attack rubber. Also note that with stock rubber bushings, grease is really not needed anyway. The carbon black in rubber helps to lubricate the bolt and often rubber bushings have steel sleeves bonded inside and there is thus no sliding contact that needs grease anyway. Simple rule of thumb: poly=grease, rubber=no grease.
    2. For maximum effectiveness, the bushings should not have a steel sleeve installed, since the idea of the greaseable bolt is to get grease in between the bolt and the bushing. If a sleeve is present then the grease can't get out of the sleeve.
    3. For example, on Toyota bushings, the sleeves have an ID of 14mm and an OD of 18mm and in the poly bushings, the sleeve is easily removable. So, if you want a greaseable bolt in a normally sleeved bushing, simply order the poly replacement bushing, omit the sleeve when installing it and specify that the bolt for the shackle be made in 18mm instead of the stock 14mm size."
    I thinks he's talking about 1st gen, but same principle. This totally off base?
  11. Dec 5, 2014 at 12:56 PM
    #351
    OZ-T
    Peter North
    British Columbia
    You can use Super Lube it's not petro based
  12. Dec 5, 2014 at 1:06 PM
    #352
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Thanks for the heads up. Still haven't got my Dakars installed yet but will have plenty of time to gather necessary hardware. I did order the set of poly bushings from wheelers.
  13. Dec 5, 2014 at 1:18 PM
    #353
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    So...let's theoretically say that someone used anti-seize instead of grease for the bolts/inside of the sleeve. Should I...I mean, they, put some grease in there? It's quiet at the moment.
  14. Dec 5, 2014 at 1:54 PM
    #354
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Anti seize is absolutely fine on the metal on metal between bolt and sleeve.
  15. Dec 5, 2014 at 2:55 PM
    #355
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Why has some taken apart their leaf packs and wire wheeled them?
  16. Dec 5, 2014 at 2:56 PM
    #356
    OZ-T
    Peter North
    British Columbia
    That's Scott , he's a dick
  17. Dec 5, 2014 at 2:59 PM
    #357
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :rofl:
    Man I don't have time for that. My shit is stacking up on floor until I can do it.
  18. Dec 5, 2014 at 3:12 PM
    #358
    TrueNorth
    Maryland
    13' V6 4X4 DCSB
    Peace of mind attained. Thanks.
    It felt right at the time, I guess it's not going to rust. As long as it keeps quiet I'm happy.
  19. Dec 5, 2014 at 5:39 PM
    #359
    scocar
    scocar Patron of the Farts
    Antiseize works great on the front main eye bolt. I buttered up my last set of Wheeler's 5-packs in, uh, a few years ago, and when I swapped them out for Daks a couple months ago, the bolts and AS looked like the say I put them in. Buttered up, bright color, no dirt or apparent degradation.
    VVVVVV
    :anonymous:Brand new, before I ever put them on.
    :humble:
    I'd bitchslap you Kevin, but I've been there too.
  20. Dec 5, 2014 at 5:59 PM
    #360
    scocar
    Brand new.
    In Malaysia, we rust you longtime GI
    I jberry'd them. Flapdick. I mean disk
    Used rust reformer and black satin in non-contact or minimal abrasion areas.
    Sprayed CRC moly lube btween leaves.
    Original "new" retainer pads on left as delivered, newer ones I called ARB for, free replacement, on right.
    OME greasable shackle bushings. I have better pics comparing this to the Wheeler's copies, which are very different with channelling for grease, including on the contact areas for the shackle side plates. I have a pic of the OME greasable bolts somewhere, and they are of a far superior quality than the grade 5 Daystar version.
