Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. May 11, 2011 at 7:12 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    seems you've gotten enough good answers.. i believe its time for me to make this thread into a true informative thread
  2. May 11, 2011 at 7:18 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I am the queen of the squeaky leaf springs....try this stuff...pry each layer apart and spray on all contact points of the leaf packs
  3. May 11, 2011 at 7:22 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Just plastidip the leafs bro, not only will they never squeek again, but you'll gain 250hp and 100mpg (378.9 liters)
    Crikeymike likes this.
  4. May 11, 2011 at 8:47 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Thanks
  5. May 11, 2011 at 9:01 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I have tried every thing short of getting them teflon coated... My advice turn up the radio.
  6. May 11, 2011 at 10:13 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Wrap a towel around them, then wrap that in duct tape.
    I've just gotten in the habit of spraying my springs down with a lube after every wash... whatever lube is closest when I reach: WD, Teflon, silicone, butter... makes them look new again and keeps them quiet.
  7. May 13, 2011 at 5:40 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I think I'm gonna go get a bunch of cans of plastidip before that tip gets out and everyone runs like mad to get it! haha
  8. May 13, 2011 at 5:50 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    OZ, you figure anything out? Got a similar issue after an AAL last weekend.
  9. May 13, 2011 at 8:16 AM
    OZ-T
    Peter North
    British Columbia
    Lots of suggestions here , but all I have done so far is spray the mud out from between the leaves which works for a while.
  10. May 13, 2011 at 8:25 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    do you know if they are poly bushings? your supposed to use a composite type grease like lithium based grease with high graphite content and that will eliminate squeaks
  11. May 13, 2011 at 8:28 AM
    OZ-T
    Peter North
    British Columbia
    Mine are the OEM bushings , we used the correct grease .
  12. May 13, 2011 at 10:42 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Mine just started squeaking yesterday :(
    Haven't even been in mud or dirt yet.
  13. May 15, 2011 at 10:47 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Mine squeak. I have done nothing for it though. One day I might, if I remember while I'm not sitting down.
  14. May 15, 2011 at 11:19 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    that happend to mine also last yr when i installed mine, after a few trips on some trails and flexing them it just went away. standing on the tail gate and jumping up and down right after the install and they squeeked i was actually pissed. now i have no squeeks and did not do anything. Get on some trails and flex them bad boys and you should be ok.
  15. May 15, 2011 at 11:20 PM
    #35
    OZ-T
    Peter North
    British Columbia
    Thanks fellas
  16. May 15, 2011 at 11:38 PM
    #36
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  17. Jun 22, 2011 at 6:22 PM
    #37
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Droop the suspension by putting jackstands under the frame and keeping the tires off the ground. Take large Screwdriver insert under leafs +pump full of brake grease. Done Repeat when leaves squeak again.
  18. Jun 22, 2011 at 7:50 PM
    #38
    OZ-T
    Peter North
    British Columbia
    I went with spray on motorcyle chain lube .
    It lasts well between the springs , the only place so far that comes back after a couple weeks is where the second leaf wraps the mounting eye at the front .
    Just shot another spray in there yesterday
    All quiet again
  19. Jun 28, 2011 at 6:55 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Update :
    The spray Motorcycle chain lube seems to work great between the flat sections of the leafs .
    Where I was getting a squeak that kept coming back was where the second leaf down from the top wraps the front hanger connection .
    At first I thought it was the bushing in the front but it is outside the bushing , there is no isolator in this location .
    I tried a variation on the bicycle innertube squeaky leaf fix and pried apart my leafs here by driving a screwdriver in between them .
    I got some EPDM rubber pond liner , which is thicker material than the innertube , cut some 2" wide strips and worked it up in there where the wrap rests metal on metal .
    Guess what ?
    Silence .
    It is pinched in there pretty good , I will leave them in there and see how it goes and how long they survive and report back .
  20. Jul 6, 2011 at 6:19 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Update #2
    This EPDM gasket works great to eliminate the squeak I had , the only issue I see , is that the rubber strip tends to migrate towards the front of the leaf over a couple days with normal driving , I have moved both back into position once in the last week .
    I am gonna try to figure out a way to restrain them because it is so awesome having a silent leaf pack !
