Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Sep 9, 2015 at 9:48 PM
    #561
    HeliMedic
    HeliMedic Off-Grid Engineering
    Erie, CO
    Constant revolving door of Toyota vehicles
    There has been discussion that using spring liner along the length of every leaf, as was done on most classic Corvettes, definitely affects the spring rate. It dramatically decreases the friction in the leaf pack, making it softer and progress through it's travel quicker.
  2. Sep 9, 2015 at 9:49 PM
    #562
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    and about 1/2" thicker
  3. Sep 9, 2015 at 9:51 PM
    #563
    HeliMedic
    Erie, CO
    Oh yeah. That too. I'll be interested to see the results.
    I definitely don't need any more height so I'll be sticking with a short section on the unprotected leaves.
  4. Sep 9, 2015 at 10:06 PM
    #564
    HeliMedic
    Erie, CO
    Very nice. Good info in that link.
  5. Sep 10, 2015 at 8:57 AM
    #565
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I'm looking forward to reading your post after install & putting some miles on with the "fix" applyed.
    Mine have been bothering me for a while now and I'm not wanting to take my leaf packs off to fix it. I may just try the Zip Tie method.
  6. Sep 10, 2015 at 9:26 AM
    #566
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    I posted about those liners a while back, glad someone's trying them.
    I'd be afraid to use adhesive though. Wouldn't want to attract any dirt. I think the center pin, leaf clamps, and the liner's channels will be enough to keep them located.
    My only reservation of going with those is the thickness. I feel they're still going to wear out like OZ's fix. Now I'm leaning towards drilling holes and installing conventional pads as a longer lasting fix.
  7. Sep 10, 2015 at 10:48 AM
    #567
    HeliMedic
    Erie, CO
    I agree. If you were to install the liner the entire length of the spring as it was designed, then yes, you would not need adhesive. The center pin would hold it in. Im only cutting short sections and installing at the tip. I'm using 3M trim adhesive which is designed for outdoor/ automotive use. Once it has bonded, it is no longer tacky.
    I just finished and was about to post pics... stand by...
  8. Sep 10, 2015 at 10:56 AM
    #568
    HeliMedic
    Erie, CO
    All done.
    Step one: Unload the rear suspension by jacking it up, placing jack stands under the frame rails, and then letting the axle droop.
    Step two: Jam a nice flat pry-bar in between the leaves.
    Step three: I cleaned in between the leaves with brake parts cleaner and a rag (mostly so the adhesive I'm using would bond nicely)
    Step four: I cut short sections of the liner, sprayed 3M adhesive on the bottom side, and placed them at the tips of each unprotected leaf.
    Step five: Finish your morning coffee that is now cold and then crack an almost-noon-beer
    Also... I used less than 3 feet of this stuff. If anyone else would like some, I'd be happy to cut off what you need, stick it in an envelope and send it out for a couple bucks. It'll save you the cost of buying the whole roll and maybe I'll recoup some of my cost of buying a whole roll. Let me know!
    4WDTrout, TacoCynGsxr and DoorDing like this.
  9. Sep 10, 2015 at 10:59 AM
    #569
    HeliMedic
    Erie, CO
    A quick spin around my block and going up and down my driveway (which usually causes the noise) revealed a much more silent ride. For some reason, I have a creaking noise coming from my front end as well... but the rear is nice and quiet.
    TacoCynGsxr likes this.
  10. Sep 10, 2015 at 11:32 AM
    #570
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    That looks nice and clean. When my zip ties wear out I might take some of that off your hands.
  11. Sep 10, 2015 at 2:50 PM
    #571
    HeliMedic
    Erie, CO
    I agree. It looks good and performs well so far. I'll keep you all updated on how it wears and whether or not it stays in place. Just let me know whenever you want some!
    Mcdees84[QUOTED] likes this.
  12. Sep 10, 2015 at 2:51 PM
    #572
    HeliMedic
    Erie, CO
    Grrr. It's always something making a racket.
  13. Sep 10, 2015 at 2:59 PM
    #573
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Its been almost two years and my dakars have been quiet for the last 12 months. The key to getting ride of the squeak is to flex out your leaf pack to the limit and get lots of dirt and mud in between the leafs. then it will be quiet.
    HeliMedic likes this.
  14. Sep 10, 2015 at 3:26 PM
    #574
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    What about PVC cement?
  15. Sep 10, 2015 at 3:38 PM
    #575
    Jeffvt0508
    Jeff
    Anderson, SC
    Wasn't sure if it work work.. it held for a few projects of mine
  16. Sep 10, 2015 at 4:01 PM
    #576
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Good attempt. I'm quite skeptical about any adhesive working on the leaf springs. Prior to the zip ties, I tried the 3M multi-surface spray adhesive and the EPDM liner stuff, it didn't last 60 minutes off road before the leaf pack chewed it up and spit it back out.
  17. Sep 10, 2015 at 4:03 PM
    #577
    Crom
    Nick
    San Diego, CA
    Millions
    ^ YOu have a good point DD, perspective is important. :D
  18. Sep 10, 2015 at 4:30 PM
    #578
    HeliMedic
    Erie, CO
    Im no stranger to the trail. I spend almost every day-off in the mountains of CO doing something. If it doesn't hold up, I'll let everyone know fairly quickly.
    Crom[QUOTED] likes this.
  19. Sep 16, 2015 at 7:24 PM
    #579
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  20. Sep 16, 2015 at 8:22 PM
    #580
    HeliMedic
    Erie, CO
    Just got back from a three day trip traveling over Taylor Pass and then Pearl Pass... from Gunnison CO to Crested Butte CO with Aspen in the middle. The passes are quite gnarly this time of year and there was no shortage of suspension flexing. Out of the 8 sections of liner I installed, 1 of them managed to migrate 1/4". The other 7 didn't budge. I'm actually quite impressed.
    YotaDan, Crom[QUOTED] and DoorDing like this.
