Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. May 9, 2016 at 8:58 PM
    #661
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    K
    I'm not sure +/- a 1/4" makes much difference or if the only difference is OME indicates the discrepency and All Pro does not but whatever floats your boat
  2. May 20, 2016 at 9:11 AM
    #662
    I3uller
    I3uller Well-Known Member
    Too far South
    So I'm about to lose my mind with these damn things. My creak is beyond annoying. Depending on the day it may or may not happen but when it does happen, it does it over everything. When I'm launching from a stop it's like moving an incredibly creaky door super slowly. When I'm braking and I stop and the truck settles back down on the rear end it creaks. Literally every bump I can hear it making quite the loud racket back there and it's like nails on a chalkboard to me. I did the zip tie method precisely where you specified and it seemed to work for a few months and now it's back to its completely loud self again. I'm about to just ditch these things and go with another leaf pack. It's absurd that a company would send out a product that is consistently flawed and makes this much noise.
    300AACTaco likes this.
  3. May 20, 2016 at 9:46 AM
    #663
    OZ-T
    Peter North
    British Columbia
    Have you tried power washing them
  4. May 20, 2016 at 9:54 AM
    #664
    I3uller
    Too far South
    I'll give it a go but I don't see that being a permanent solution. I'm getting some dry moly and going to give that a shot.
  5. May 20, 2016 at 9:58 AM
    #665
    OZ-T
    Peter North
    British Columbia
    Its not a permanent solution , its a maintenance thing
  6. May 20, 2016 at 10:12 AM
    #666
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    The more I think about my situation (which sounds like yours @I3uller) I'm thinking I didn't grease the bushings enough before mounting to the shackles. The zips ties seem to do fine with the noise from the leaf pack, but I know I'm getting almost all of my noise from my bushings b/c when I lube them with lithium grease, they go silent. I'm think about putting an AAL in the pack to get some rake back. If I go that route (garage clearance pending), I'm going to grease the snot out of the bushings and see if that solves the problem once and for all for me.
  7. May 20, 2016 at 10:13 AM
    #667
    I3uller
    Too far South
    No need to be a dick about things. OEM makes no noise, Dakar makes an insane amount of noise with way more maintenance on them. It's already been shown in this thread that the Dakars are built without the silencers that should be there. It's just annoying that they send out a product that's had this issue consistently for years. I'm just trying to find out a way to rig them to be reasonably decent without pressure washing them every week.
  8. May 20, 2016 at 10:14 AM
    #668
    I3uller
    Too far South
    I know when I put my bushings in, I excessively greased them but I'm also not sure entirely where the noise is coming from.
  9. May 20, 2016 at 10:17 AM
    #669
    OZ-T
    Peter North
    British Columbia
    I'm not being a dick , I'm saying you still need to periodically clean between the leafs or you will still get noise
    Somebody should start a thread to try to help people solve this problem
    Norton, TRDKS, Crom and 1 other person like this.
  10. May 20, 2016 at 10:18 AM
    #670
    Mcdees84
    Tallahassee, FL
    I don't think he was being a dick. Brevity can be key sometimes and Oz has answered plenty of questions i this thread. Nothing wrong with being short and to the point. Relax a bit man, we're all trying to find the right fix.
    Another thing I read was to loosening the bolts in the shackles with the weight of the vehicle on, then circulate the suspension (i.e., jump up and down on the bumper a bunch) and then retorque to spec. Just Don't take the bolts out while doing this, just loosen.
    Norton, 4WDTrout and Crom like this.
  11. May 20, 2016 at 10:18 AM
    #671
    Mcdees84
    Tallahassee, FL
    :rofl:
    Crom likes this.
  12. May 20, 2016 at 11:22 AM
    #672
    I3uller
    Too far South
    Yea not being a dick at all. Thanks for the informative and helpful comments.
  13. May 20, 2016 at 11:24 AM
    #673
    I3uller
    Too far South
    Thanks for the actually helpful tip. Have you tried this and had any luck with it? I'll probably give it a go regardless since it's quick and easy.
  14. May 20, 2016 at 11:54 AM
    #674
    OZ-T
    Peter North
    British Columbia
    You're welcome
    Mr.PowerTrays likes this.
  15. May 20, 2016 at 12:20 PM
    #675
    Mcdees84
    Tallahassee, FL
    I think I read that after I tried loosening and re torquing; so I didn't cycle the suspension. My torque wrench has disappeared, so I'm waiting till I swing by my father-in-laws next to give it another go.
  16. May 20, 2016 at 12:29 PM
    #676
    I3uller
    Too far South
    Lol touché. Busy morning and that creaking had me all riled up. You can see why I need to figure this thing out haha
  17. May 20, 2016 at 12:53 PM
    #677
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    sorry couldn't seem to find it, but what is the width of the dakars?
  18. May 20, 2016 at 1:01 PM
    #678
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I called ARB USA and a rep recommended that I try this to help fix the squeak.
    He said that he's fielded Many calls on this subject and they are implementing design changes soon(I can't remember the time frame he gave me). Personally, I'm going to do all 3 fixes:
    1) Crom's Zip Tie Fix
    2) Dry Moly Lube
    3) Loosen the bolts securing the leaf pack to the shackles & frame and retorque them to spec after jumping up and down on the rear bumper
    Call ARB and see what they tell you
    http://www.arbusa.com/
    (425) 264 1391
    Toll Free: (866) 293-9078
    DrFunker and Mcdees84[QUOTED] like this.
  19. May 21, 2016 at 2:31 AM
    #679
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  20. May 21, 2016 at 2:45 AM
    #680
    DrFunker
    DrFunker Well-Known Member
    I like the sound of this. :popcorn:
    4WDTrout[QUOTED] likes this.
