Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Jun 6, 2016 at 11:22 AM
    #701
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    FYI - for anyone else who knows that at least some of the noise is coming from the front bushings (like me), I emailed ARB over the weekend asking for additional suggestions beyond buying greasable shackles. They are sending me new bushings for free. I'll let you know if that worked after they're installed.
    I'm also adding an extra leaf to help with the added weight of bedrack and RTT, so I'm going to install the spacers mentioned in here at the same time to replace my zip ties (which worked flawlessly for those waiting to try that method). Fingers crossed for not having to carry lithium grease in my truck anymore!
    DJ KRAZY K likes this.
  2. Jun 7, 2016 at 11:58 AM
    #702
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    OK so I just got my dakars in, and this weekend I will be drilling holes and installing the spring pads, also while they are apart I will put on an extra coat of paint. Is there anything else I should do before install? Also should I still use Molly lube when putting them back together or does the pad eliminate the need for that?
  3. Jun 7, 2016 at 1:56 PM
    #703
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    None of my noise is coming from the front bushings
  4. Jun 7, 2016 at 2:07 PM
    #704
    DrFunker
    DrFunker Well-Known Member
    Got my squeaky leafs today. :yes:They are actually pretty quiet.
  5. Jun 7, 2016 at 2:53 PM
    #705
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    It's a matter of time. Mine were quiet at first as well...
    Then again, my buddy has a set on his Tacoma for a while now and he says he's never had squeaking issues. Keep your fingers crossed.
    DrFunker[QUOTED] likes this.
  6. Jun 7, 2016 at 3:31 PM
    #706
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Are yours squeaking?
  7. Jun 7, 2016 at 10:46 PM
    #707
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    Or it rains in the mall parking lot:facepalm:
  8. Jun 8, 2016 at 6:24 AM
    #708
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You should be fine without the Molly, if doing spacers.
    However, If it were mine, is still hit them with Dry Molly anyway. It can't hurt, and if anything it will help the leaf pack flex and I think it helps resist corrosion some.
    Mr.PowerTrays[QUOTED] likes this.
  9. Jun 8, 2016 at 8:00 AM
    #709
    DrFunker
    Could someone point me to a write on the drilling procedure?
    Also, @ROK-NJA What type of paint are you using?
  10. Jun 8, 2016 at 9:07 AM
    #710
    OZ-T
    Peter North
    British Columbia
    Have you tried either method in the OP ?
  11. Jun 8, 2016 at 9:10 AM
    #711
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Hahaha I hear ya brother!
    People look at me as if my truck is falling apart...
  12. Jun 8, 2016 at 10:27 AM
    #712
    OZ-T
    Peter North
    British Columbia
    V
  13. Jun 8, 2016 at 10:29 AM
    #713
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Working on it. This weekend I'll wrap that middle leaf on the front side of the pack in zip ties and possibly spray some dry moly lube as well. I've been pretty busy lately and have not had the time to tinker with it. I'll post up my results after
  14. Jun 8, 2016 at 11:14 AM
    #714
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    from what ive read carbide bit, slow speed, high pressure, lots of cutting fluid! my buddy has a drill press but im not sure if it will be slow enough
  15. Jun 8, 2016 at 11:16 AM
    #715
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    also ill be using rust-oleum high performance enamel to paint them
  16. Jun 8, 2016 at 11:43 AM
    #716
    OZ-T
    Peter North
    British Columbia
    Drill presses have multiple speeds depending on how you arrange the belts on the gearing wheels
    Mr.PowerTrays likes this.
  17. Jun 8, 2016 at 1:44 PM
    #717
    DrFunker
    @tacobell007 Any thoughts about this?
  18. Jun 8, 2016 at 1:49 PM
    #718
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    What are you drilling?
  19. Jun 8, 2016 at 2:27 PM
    #719
    DrFunker
    The leafs.
  20. Jun 8, 2016 at 2:40 PM
    #720
    tacobell007
    Drew
    Western MA
    Why's that?
