Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Feb 14, 2018 at 4:49 PM
    #1001
    CaliBluTaco
    CaliBluTaco Well-Known Member
    Nathanael
    Ohio USA
    07 Tacoma TRD Off Road
    Brute Force Fab Hybrid Front Bumper, Brute Force Fab HC Rear Bumper, All Pro Kickout Sliders, Pelfreybilt IFS Skid and Mid Skid, Relentless Fab Tailgate Reinforcement, ICON Ext.Travel Coilovers w/ 14"x 650# Eibach coils and custom valving, LR UCA's, OME Heavy Duty Rear Leaf Pack w/ All Pro U-Bolt Flip, Icon 2.0 Aluminum Series Extended Travel rear shocks & Wheelers Super Bumpstops. 285/70R17 Hankook Dynapro MT RT03 Tires on 17x8 Pro Comp 7089's, ENGO E12000s Winch w/ Synthetic Rope, Locker Anytime Mod, Rear Diff Breather Mod, and more...
    I don’t think those would work on 2Gen Tacoma’s. The spring hangers and shackles are designed differently to accept a 14mm size bolt instead of the older style 18mm size bolt that was used in previous Toyota’s. Hence the metal sleeve that needs to be used in the polyethylene bushings of the 2 Gen Tacoma’s. That’s what I’ve gathered from searching around.
    GHOST SHIP[QUOTED] likes this.
  2. Feb 14, 2018 at 4:50 PM
    #1002
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Gotcha, carry on.
  3. Feb 14, 2018 at 5:27 PM
    #1003
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    You can get greaseable shackles from Defined Engineering , not sure about just bolts though
    https://www.definedengineering.com/products.html
    DoorDing likes this.
  4. Feb 14, 2018 at 5:45 PM
    #1004
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Mine came with isolators but with the crappy front rubber bushing. Moves around like crazy and is nearly pushed all the way to one side. Also pops loud and harsh when flexing.
  5. Feb 14, 2018 at 6:09 PM
    #1005
    ThomasMore66
    Dallas/Fort Worth & Durango
  6. Feb 14, 2018 at 6:25 PM
    #1006
    OZ-T
    Peter North
    British Columbia
    Not that I'm aware of , no
  7. Feb 14, 2018 at 7:05 PM
    #1007
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Kolunatic and DoorDing like this.
  8. Feb 14, 2018 at 7:17 PM
    #1008
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    I believe they offer a discount if you order direct as well. @Dobinsons Mike is who would know for sure.
  9. Feb 14, 2018 at 7:41 PM
    #1009
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  10. Feb 14, 2018 at 8:29 PM
    #1010
    ThomasMore66
    I’ve wondered where the Oz man had gone.
  11. Feb 14, 2018 at 8:49 PM
    #1011
    ThomasMore66
    Did it involve Olympic figure skating?
  12. Feb 14, 2018 at 9:12 PM
    #1012
    ThomasMore66
    Made me laugh!
  13. Feb 14, 2018 at 9:17 PM
    #1013
    OZ-T
    Peter North
    British Columbia
    Get out of my thread
    Crom and DoorDing like this.
  14. Feb 15, 2018 at 4:41 AM
    #1014
    CaliBluTaco
    Nathanael
    Ohio USA
    I found these threads on Dobinsons greasesble pins in doing some digging on TW. Thought it might help out a little in explaining what the pin actually greases.
  15. Feb 15, 2018 at 5:21 AM
    #1015
    griffin407c
    Upstate NY
    Thanks for the research. My plan was to drill small holes in the sleeves as well. Possibly a small hole on each end of the sleeve. I have a drill press, might as well use it.
  16. Feb 15, 2018 at 6:00 AM
    #1016
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    That OME bushing needs to go. You can probably disconnect the front of the pack, and simply hammer strike with a large socket to get it out. It won't take much.
    Good idea.
    ChadsPride likes this.
  17. Feb 15, 2018 at 6:03 AM
    #1017
    CaliBluTaco
    Nathanael
    Ohio USA
    Your welcome :thumbsup:
    Sounds like a good plan. Anything to get some grease in between the bolt sleeve and the polyurethane bushing. I’m pretty sure that’s where the noise is mostly coming from. I read another thread where they were drilling out the holes in the spring hangers and shackles to accommodate the 18 mm greasesble bolts sold for the older Toyota’s. Of course you wouldn’t need the metal sleeves in the bushings anymore and it would grease up the bushing even better. But I’m not sure if that’s a good idea or not :confused:
  18. Feb 15, 2018 at 6:08 AM
    #1018
    Crom
    Nick
    San Diego, CA
    Millions
    Nah. A fully greasable shackle is the way to go. I modified OEM ones.
  19. Feb 15, 2018 at 6:52 AM
    #1019
    griffin407c
    Upstate NY
    Just bought some Dobinsons greasable pins for the front and rear. I have plans to also drill the sleeves. Once the pins get here, I'll report back.
  20. Feb 15, 2018 at 10:52 AM
    #1020
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    I'm not running darkars yet but on my stock leaves with ICON AAL I find routine use of Fluid Film keeps them quiet. They were making noise at one point after a year of not coating. I sprayed them down and it went away.
