Squeaky Dakars : Any advice from others with the Dakars ?
Discussion in 'Suspension' started by OZ-T, May 10, 2011.
  1. Mar 28, 2018 at 6:38 PM
    #1041
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    Luckily I have the ability and tools to do this myself. Are you going to have the sleeves cross drilled? The poly bushings don't make contact in the center so there is a slight gap for the grease to transfer from the bolt, to the sleeve, and then to the bushing.
    Kolunatic likes this.
  2. Mar 29, 2018 at 5:23 AM
    #1042
    griffin407c
    Upstate NY
    Nice. Mine are showing some slight rust on the springs where the paint was chipped during shipping. My springs will be cleaned and smothered in fluid film sometime this spring. It's a battle combating the salt here and trying to maintain a rust free truck.
  3. Mar 30, 2018 at 2:20 PM
    #1043
    griffin407c
    Upstate NY
    Well ladies and gentlemen, the squeaks were completely gone after cleaning and installing the Dobinsons 2 days ago, but now they're back. The squeaks are definitely less dramatic and less often, but they're back. The top two springs make contact about 6" back from the front isolators, so that area is the next place I'll be looking at.
    DoorDing likes this.
  4. Apr 3, 2018 at 8:36 AM
    #1044
    griffin407c
    Upstate NY
    .... and then, mysteriously, one day, the squeaks went away. Lol this is ridiculous.
  5. Apr 3, 2018 at 12:43 PM
    #1045
    uwjberg
    uwjberg Well-Known Member
    Thanks for this - I have the updated medium Dakars and the squeaks were driving me nuts. Pulled the isolator pads out and they were bone dry with just dirt packed in there. Cleaned them out and applied some marine grease and the squeaks are gone. I had been spraying dirtbike chain lube in there, but that would only last a couple of days. Been a week now with no return of the squeaks.
  6. Apr 4, 2018 at 12:34 PM
    #1046
    ciscofran
    ciscofran Well-Known Member
    Francisco
    Cali
    2005 Indigo Tacoma Access Cab - TRD Sport
  7. Apr 4, 2018 at 12:36 PM
    #1047
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I forgot to do it and now I’ve got Dakars on! But that stuff is super handy and they have it at Home Depot for like $5.
  8. Apr 4, 2018 at 12:43 PM
    #1048
    ciscofran
    Francisco
    Cali
    Gotcha, I might just give it a try.
    Did you ever end up getting these installed?
  9. Apr 5, 2018 at 10:39 AM
    #1049
    griffin407c
    Upstate NY
    After replacing the bolts with the Dobinsons a week ago..... no squeaks at all, kinda squeaks, no squeaks, slight squeak, and now right back to full on annoying squeaks again. :annoyed::frusty:
  10. Apr 5, 2018 at 4:52 PM
    #1050
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    What bushings is everybody using?? My friend found me some rubber OEM-like bushings. They're twice as expensive as the poly stuff, but I'm anticipating no squeaks from them.
    My old Allpros squeaked a lot from just rust/shit in the leafs themselves. Cleaning them out and Fluid Film lasted a couple weeks. I just bought some of that Energy Suspension 'sticky' grease for future leaf squeaks. Most people that use it say it lasts 6+ months.
  11. Apr 5, 2018 at 11:40 PM
    #1051
    ciscofran
    Francisco
    Cali
    Gotcha, I just got some used Dakars and while in the process of cleaning them up I thought I'd address the potential for squeaking. I'm thinking of just spraying everything with Rustoleum chassis paint and greasing the hell out of everything with a substance high in graphite. The ones I got use the yellow spring bumpers beneath the 3rd and 4th leafs so I'm thinking of wrapping the 2nd leaf with a couple of zip ties for good measure.
    I'm also replacing the center pin and greasing the bushings. Hopefully I've covered all my bases by the time i'm done.
  12. Apr 6, 2018 at 1:31 PM
    #1052
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    I'm late to the party so sorry if you've already mentioned this but have you tried spraying everything liberally with fluid film?
    lynyrd3 likes this.
  13. Apr 7, 2018 at 6:43 AM
    #1053
    griffin407c
    Upstate NY
    That's my future plan. I also plan on adding the add-a-leaf. The add-a-leaf doesn't come with the isolator pads, so I'll be using my plasma cutter to bore holes instead of spending forever on a drill press and burning up bits. Once everything is apart, I'll be cleaning, applying some sort of lube on the pads, possibly adding some spring liners, and then apply fluid film super heavy.
  14. Apr 9, 2018 at 3:44 AM
    #1054
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Going on 50000 miles and so far no squeaks.
    lynyrd3 and Kolunatic like this.
  15. May 29, 2018 at 3:23 PM
    #1055
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Knock on wood but i added the zip ties and it actually worked! :bananadance:
  16. Jul 10, 2018 at 8:15 AM
    #1056
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Do you mind let me know what's the correct size liners for the Dakars HD?
  17. Jul 10, 2018 at 3:24 PM
    #1057
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I got bad case of tennitus
    I don’t hear shit:annoyed:
  18. Jul 10, 2018 at 3:40 PM
    #1058
    RicanTacoma
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Sorry, i meant when you find out
  19. Jul 13, 2018 at 5:34 PM
    #1059
    RicanTacoma
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Hello All,
    I just picked up a new set of OME Dakars, EL095R, and they look to have a round button between the 3 top leaf springs.
    Are those anti squeak insulators? Do I still need liners?
    Sorry Am new to this,:oops:
    edit, Never mind, I found the information on the OME website.:facepalm:
  20. Aug 8, 2018 at 4:35 AM
    #1060
    lynyrd3
    Bill
    East Central Upstate NY
