Squeaky Dakars fixed by driving off-road, wtf?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gudujarlson, Oct 4, 2021.
  1. Oct 4, 2021 at 10:35 AM
    gudujarlson
    gudujarlson [OP] Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My OME Dakar leaf springs had been squeaking quite badly prior to a trip up north to hit some trails. After spending some time on the trails they no longer squeak. I did not expect this. Usually it works the other way around. My only slightly plausible explanation is that they got cleaned up by the large amount of water on the trails. It was raining, the soil is very sandy, and thus the puddles contained relatively clean water.
  2. Oct 4, 2021 at 10:56 AM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Squeaking is usually metal-on-metal contact. Could be the opposite, they could now be dirtier, with the debris acting as "lubricating" layer.
  3. Oct 4, 2021 at 11:09 AM
    gudujarlson
    Minnesota
    Well, like I was trying to say, in the past they have started squeaking (more) after getting dirty. Cleaning them with a pressure washer has usually helped, but has not always cured the problem entirely.
  4. Oct 4, 2021 at 11:21 AM
    rosswood
    rosswood Well-Known Member
    Ross
    South Florida
    2017 SR5 Magnetic Grey
    Current Build: 18” Level 8 Slam Wheels LT285/65/18 Nitto Terra Grappler G2 Icon Stage 1 Lift Kit 2.75” OME HD Dakar Leaf Springs w/extra leaf Caliraised 32” Hidden Dual Row LED LightBar Caliraised Ditch Lights RCI Offroad Short Bed 12” Rack ROAM Adventure Vagabond RTT
    https://youtu.be/zCf3Bw529rY
    Add this to your routine with better silcone grease after a good pressure wash. My OME leaf springs havent made a peep in months, and for some reason the grease fitting feature isnt in a manual or instruction packet from OME.
    side note: Before when mine would get wet they would normally stop until they dried out again.
  5. Oct 4, 2021 at 11:40 AM
    gudujarlson
    Minnesota
    Mine are still not squeaky after drying out. I didn't need to lube, although I have had to in the past.
  6. Oct 4, 2021 at 11:50 AM
    rosswood
    Ross
    South Florida
    Problem solved then!
  7. Oct 4, 2021 at 11:53 AM
    gudujarlson
    Minnesota
    Exactly, but it was not expected.
  8. Oct 4, 2021 at 11:53 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    This is the Tacoma version of an Italian tune up.
  9. Oct 4, 2021 at 12:09 PM
    bzzr2
    bzzr2 Well-Known Member
    Don't worry, the noise will come back to keep you company! Mine would come and go as normal Dakar behaviour.
  10. Oct 4, 2021 at 12:12 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'm guessing there's a 97% chance it's a temporary fix.
    bzzr2 likes this.
  11. Oct 4, 2021 at 12:16 PM
    gudujarlson
    Minnesota
    I do not doubt that!
  12. Oct 4, 2021 at 12:19 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    High end 1911's like a Dan Wesson or Ed Brown are fit together very tightly and require a decent amount of use to allow the internals to "self polish" for good fit & proper operation. I'm guessing the sandy soil you mentioned "polished" the squeaky tight spots in the leaf pack.
    I'd also be willing to bet there's a bit of sand "lubing" up your leafs now, especially if the sand is quartz based or made up of something with similar mineral hardness.
  13. Oct 14, 2021 at 7:08 PM
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    Is there a quiet or silent alternative rear suspension for a Tacoma then? I'm in the market for replacement for my factory rear set with an add a leaf and block installed. Would rather go to just a straight leaf pack as opposed to all the squeaky à la carte lift pieces I have now.
