Squeaky doors !! door check arm problem? ... Nut-Z lube app seemed to fix it
Discussion in '1st Gen. Tacomas (1995-2004)' started by GQ7227, May 13, 2019.
  1. May 13, 2019 at 9:07 AM
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    squeaky doors with climate change lately have me disgruntled a bit
    tried lubing hinges (with spray) but not good solution
    I have isolated the problem to this piece ... 'Door stop limiter arm' or 'Door Check'
    a very annoying deep throaty squeak, tried shooting wd40 and some teflon lube inside the door part but the squeak remains
    anybody have a squeak and have you eliminated it?
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-check-arm-6861004010/?c=YT10b3lvdGE=
    TurbulentLamp likes this.
  2. May 13, 2019 at 9:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll be the first to say, that door jamb is clean.
    rogerman and GQ7227[OP] like this.
  3. May 13, 2019 at 9:11 AM
    GQ7227
    J A Y
    thanks, it can always be cleaner :thumbsup:
    plus the climate I live in its imperative to keep clean
    the throaty croak is coming from piece going inside the door
  4. May 13, 2019 at 9:13 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Mine does the same thing , I just live with the noise !!!!
    GQ7227[OP] likes this.
  5. May 13, 2019 at 9:15 AM
    GQ7227
    J A Y
    :annoyed: it's just old age I guess, no good fix for it?
    US Marine[QUOTED] likes this.
  6. May 13, 2019 at 9:19 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    I read somewhere that you've got to pull the door panel off to access that door stop mechanism to properly fix this issue . Mine doesnt do it all the time so I've learned to live with it
    GQ7227[QUOTED][OP] likes this.
  7. May 13, 2019 at 9:21 AM
    firstgentacotuesday
    firstgentacotuesday Well-Known Member
    CA
    ‘01 3.4 4x4
    I know how you feel, a buddy of mine likes to open and close the door over and over because of that squeak lol. I just deal w/ it:notsure:
  8. May 13, 2019 at 9:21 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try “white lithium” spray lube. Get a can with a red tube spray attachment. Puts the lube where you want it.
    jammer, GQ7227[OP] and US Marine like this.
  9. May 13, 2019 at 9:25 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Tries that also was only a temporary bandaid , it lasted maybe a week then the noise came back
  10. May 13, 2019 at 9:27 AM
    GQ7227
    J A Y
    it doesn't do it when the temps are cold, only with high humidity and hotter temps
    these panels have never been removed, maybe there is original 'grease' inside there plastic on metal? that has finally dried and/or caked?
    i tried some teflon stuff, swung door to and fro and still nothing, no elimination
  11. May 13, 2019 at 9:38 AM
    GQ7227
    J A Y
    @RysiuM your doors are older than mine!
    do yours squeak in this area?
  12. May 13, 2019 at 9:46 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Now I'm screwed. I will always hear that sound. I never paid attention as it is not loud. But now after you told me I will hear it forever :). The only hope is that with age my hearing will be worse and worse.
  13. May 13, 2019 at 9:47 AM
    GQ7227
    J A Y
    maybe your current climate is not hot and humid like it is here?
    it does NOT squeak (that I can tell) with temps near freezing
    plus this squeak has been going on for many years, its not a 'new' occurrence
    just thought maybe somebody has discovered a 'best' method for eliminating it
  14. May 13, 2019 at 10:49 AM
    RysiuM
    Rysiu
    Sometimes my door made sound like from a horror movie when opening old door to a cellar, but that was easy to eliminate by lubricating hinges (don't ever use WD-40 for lubrication, it makes things worse). The sound from the stopper is faint and did not even notice it till I read your post. My office chair makes more noise than that.
  15. May 13, 2019 at 11:39 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  16. May 13, 2019 at 11:40 AM
    GQ7227
    J A Y
    i am fairly certain it is NOT the upper or lower hinge, but maybe I'm wrong
    I held the little plastic thing in the middle as I was moving door and felt vibrations
    I would like to know what the part looks like to see if it needs greased inside door panel that I cannot get to from the jam
    US Marine likes this.
  17. May 13, 2019 at 11:42 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes that's the Door stop limiter arm and I'm getting the exact symptoms
  18. May 13, 2019 at 12:09 PM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Same thing here. Its also only my driver door ... I have tried a fair number of lube, I hope there is a fix.
  19. May 13, 2019 at 12:18 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So i struggled with this like most of you until i found the cause - at least for my driver side door. Cant believe how simple it was and why i never checked.
    Check both hinges (top and bottom) as well as one bolt behind the cover of the door stop - make sure all are snug.
    My lower hinge was loose. Tightened and noise is gone.
  20. May 13, 2019 at 12:20 PM
    Yota.jr
    Yota.jr Well-Known Member
    Vancouver Island B.C.
    18~Yota-xcab~6spd & 98 too:)
    My old 84 Yota was terrible...I put smallest amount ever dry grafite on..as I remember 1 time only and it silenced that lil squirrel..haha
