Squeaky doors !! door check arm problem? ... Nut-Z lube app seemed to fix it
Discussion in '1st Gen. Tacomas (1995-2004)' started by GQ7227, May 13, 2019.
  1. May 13, 2019 at 12:22 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    You want silicone spray. Not white lithium or Teflon. Start there
    wilcam47 and GQ7227[OP] like this.
  2. May 13, 2019 at 12:23 PM
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    the metal hinge at the very bottom?
    i would not think my hinges to be off since it still closes like a champ as nearly brand new as one can get without actually being new lol
    i will go and see about tightening it up see how it works then
    Area51Runner[QUOTED] likes this.
  3. May 13, 2019 at 12:29 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I applied all purpose grease to mine and havent heard a sound since.
    Hamer95USA and GQ7227[OP] like this.
  4. May 13, 2019 at 12:37 PM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    Don't use wd40, it "cleans" the grease out. One you use that you'll have to clean the WD out and reapply some real grease.
  5. May 13, 2019 at 12:41 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    yes, the two bolts per hinge on the door side. Check just to be sure. My hinge was not snug. Did it impact the door closing? NO. It did cause that damn OCD annoying squeaking noise though.
    GQ7227[QUOTED][OP] likes this.
  6. May 13, 2019 at 12:59 PM
    GQ7227
    J A Y
    did you have to remove the panel to get to the inside of this door stop limiter arm? door check arm?
    i wonder if that WD40 all these years messed it up inside, dried all the grease out
  7. May 13, 2019 at 1:03 PM
    Taco302
    Greenbow, Alabama
    I applied it to everything i could see with the door fully opened. When you open and close it works the grease into the door. Glob that shit on there.
  8. May 13, 2019 at 1:03 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    There's a screw inside that plastic cover, its very easily stripped out of the threads over time. The squeak you might be hearing could be the screw being 'pulled' in and out of the sheetmetal.
    happened to my friends '99 !
  9. May 13, 2019 at 1:06 PM
    Area51Runner
    did you check the hinge bolts?
  10. May 13, 2019 at 1:09 PM
    GQ7227
    J A Y
    i will this evening
    the door has never been taken off and not sure how they would work loose but worth a shot!
  11. May 13, 2019 at 1:14 PM
    Area51Runner
    To the best of my knowledge, the door hasn't come off in the past 17 years I've owned it either ;)
  12. May 13, 2019 at 1:23 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    I put moly grease on mine after doing the u joints. No squeak.
    GQ7227[OP] likes this.
  13. May 13, 2019 at 1:25 PM
    GQ7227
    J A Y
    I am just a short drive down I-80 (about 1700 miles) I will get you a tall cold beverage if it works
  14. May 13, 2019 at 2:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    On second thought, you don't need no stinkin' doors -
  15. May 13, 2019 at 2:26 PM
    #35
    GQ7227
    J A Y
    it gets well below freezing here
    i already went through that decades ago (quarter century more like it) delivering winter pizza in a '79 Corolla that the heater and defrost did not work
    had to scrape the frosty inside windows with my drivers license :(
    Kwikvette[QUOTED] likes this.
  16. May 13, 2019 at 2:36 PM
    #36
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    That reminds me my POS Zastawa (Yugo). After skiing everybody was undressing for trip home, I was putting all cloths on. In that POS car windows did not go all way up - no heating would warm that cabin when the cold wind was blowing through all windows.
  17. May 13, 2019 at 6:33 PM
    #37
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Door Check Assembly 6862004010. You do have to remove door trim but not too difficult.
    Just so you know, it may not be the check assy making the noise. There is a reinforcing plate welded in there where these bolt up. Basically a double thickness of metal, with one spot welded over the other. It may be the R/F plate and the door sheet metal rubbing against each other due to the stress. Your lube may not be getting in between the two panels.
  18. May 13, 2019 at 8:59 PM
    #38
    GQ7227
    J A Y
    https://parts.lakelandtoyota.com/p/__/CHECK-ASSY--FRONT-DOOR--LH/4113333/6862004010.html
    i am under the assumption that the metals are expanding/contracting with the outside temperature change?
    in the winter this never happens!
    if I choose to put new door speakers in I should have better access to the innards?
    i was able to tighten maybe a micrometer, did not want to test my own strength and break a bolt or slip and put a dangerous mark in my inside doorjam paint
    its a wait and see if the noise goes away after this
  19. May 18, 2019 at 9:21 AM
    #39
    GQ7227
    J A Y
    i did not try this one bolt, just the hinges
    what needs to be removed to access that, the black plastic piece?
    if i have to go route with the grease how messy is that going to get, cleaning the jams up after treatment
    did all the wd40 used in 2 decades do harm, i always thought that is best stuff to use oh how i was ill informed
  20. May 18, 2019 at 6:14 PM
    #40
    1997tacomav6
    Denver
    I give it a shot of bead blaster stick the tube in there as far as I can spray it as I close the door and open it and it always seems good for at least a year
