Squeaky front brakes 2009 dcab 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by douggytundra, Oct 28, 2010.
  1. Oct 28, 2010 at 6:18 AM
    douggytundra
    douggytundra [OP] Well-Known Member
    orlando
    09 D-CAB 4x4 White Sport Taco
    My 09 dcab has noisy front brakes. I have 14k and they are squeaky at slow stops. I have had it to toyota 2 times already and they can't figure it out and now they tell me this is normal.... This is my 3rd gen 2 and I have had 2 gen 1's without this problem. So they are just full of shiz.... Any ideas.....
  2. Oct 28, 2010 at 8:15 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My 09 is at 12k and is doing the same thing. I have not taken it in though. What has Toyota done so far?
  3. Oct 28, 2010 at 8:16 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I got 27k and mine started to do that.
  4. Oct 28, 2010 at 8:19 AM
    douggytundra
    orlando
    They first resurfaced the rotors than they adjusted the rear brakes. None of these things worked. I am wondering if the pads should be replaced...
  5. Oct 28, 2010 at 8:27 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    Join the club. My '09 front brakes squealed in the same situation (slow, rolling stops especially), so at 35k I changed the pads with high performance, no-squeak ceramics. The old pads still looked brand new, by the way. No luck, same exact thing still happens. I think it's just a characteristic of the truck.
  6. Oct 28, 2010 at 8:35 AM
    newbtacoma
    newbtacoma Well-Known Member
    Houston, TX
    2010 Super White Sport
    My wife's 2007 murano has this problem - I have replaced the rotors and pads 2 different times, only for the problem to come back about 2000 miles later.
  7. Oct 28, 2010 at 8:46 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    That should be the next step. Normally the squealing is due to the pad vibrating in the caliper. So checking the springs/retainers, lubing the slides, adding anti-squeal compound to the pad backs, and cleaning the calipers will "normally" work. This is what I would expect Toyota to do first. Squealing IS NOT normal, don't let them use this.
    That being said, my wife's 02 Mazda Tribute developed this squealing a couple year into ownership. I tried everything I could think of, all the above plus different pad types, re-surface the rotors, then replace the rotors. Squealing always came back. On my previous truck, 02 Dakota, it started squealing, I replaced the pads, it went away, quick and easy.
  8. Oct 28, 2010 at 8:56 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    eh, pretty normal. wait til you go wheeling with a bunch of tacomas, all you hear is the same exact squeak lol
  9. Oct 28, 2010 at 11:14 AM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    Same thing on my 2010 dc with less than 7k miles on it.
  10. Oct 28, 2010 at 11:43 AM
    douggytundra
    orlando
    Oh no I am on them like white on rice..Like I said I have owned 1995,2003,2005,2006 taco's and never heard this. I have also owned 2-2005's and a 2006 tundra and my wife has a 2006 4runner and nothing like my 09.
  11. Feb 21, 2011 at 4:40 PM
    jmoreau
    jmoreau Well-Known Member
    Josh
    Baton Rouge, LA
    '11 MGM DC TRD Sport 4x4
    Has there been any solutions to this? My '11 Taco is doing it at 7K miles. Pretty embarrassing b/c it still looks brand new but sounds like crap!
  12. Feb 21, 2011 at 4:47 PM
    douggytundra
    orlando
    They had it for 8 hours and replaced all the pads and shoes and lubed everything all over again. Now toyota is involved and they are checking it out. It has been fine until just recently when I heard it again leaving my driveway last week. Hope it is just a fluke but we will see..
  13. Feb 21, 2011 at 4:50 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Metallic composite pads (like the factory ones on the Tacos) just do this sometimes. It's normal. I ignore it.
  14. Apr 25, 2011 at 8:51 AM
    jmoreau
    Josh
    Baton Rouge, LA
    I took mine to the Toyota dealer at 7K miles, and they finally said they had to "remove foreign matter" from the rear brakes. Two days later the squeak was back. I brought it in over the weekend for my 10K oil change and tire rotation and told them it never stopped. I also mentioned that a lot of people say theirs does it and Toyota can't figure out the problem (along with how embarrasing it is to have a new truck squeaking like that in traffic). They said they looked at it again and said they'll have to order some "special parts". I hope that means aftermarket pads or something totally different than stock. Should be in later this week, so I'm keeping my fingers crossed that they can fix it.
  15. Apr 25, 2011 at 8:56 AM
    DevL
    DevL Well-Known Member
    The issue is that the pad compound toyota uses is geared toward longevity and not being quiet. The solution is a ceramic brake compound... this changes the steel brake pad component to copper and stops squeal. Taking it to toyota will never solve your problem.
    Brake squeal absolutely normal on the tacoma don't let anyone tell you different. The rear drums will groan horribly off road as well... again due to the compound that is used. Solution... ceramic shoe compound.
