Squeaky front end (my experience & fix)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by themanbearpig012, Nov 4, 2020.
  1. Nov 4, 2020 at 11:56 AM
    themanbearpig012
    themanbearpig012 [OP] Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    So as I'm sure all of you on here are aware the "front end noise squeak" seems to be a common problem with these trucks. As you search and search for information on what the cause may be you'll come across the following:
    -Radiator Cab Mount bushings need replacing
    -"is it maybe coming from the leaf springs?"
    -Body Mount bushings
    -UCA bushings
    those are just some of the things of come across. However, they seem to be the most popular.
    With that said when I came across my front end squeak and dove into the search of trying to figure out what it was. It seem to me that it was more than likely the the cab mount bushings. So, I went ahead and decided to order some and replace them
    https://www.tacomaworld.com/threads...-mounts-cab-also.361346/page-70#post-23519600
    As you can see the old ones were pretty shot. Turns out that wasn't the issue though. But hey at least I got them replaced before they became a problem right?
    So back to search I go. the more dove into the search the more I kept getting lost and frustrated so honestly I just gave up the search. Oddly enough, the squeak would stop for up to a week or so and then come back with almost a vengeance. And yet it would stop again. Lived with it like that for MONTHS. Now it was really starting to get to me for some reason so I started searching yet again but this time just via google and not to much TW. found that a silicone lubricant spray would be a place to start and spray everything movable suspension piece and see what happens. So I did. And yet the squeak continued. I then realized that I never lubed the LCA bushings.... I then DRENCHED those bastards with https://www.amazon.com/BLASTER-16-SL-16-Oz-Aerosol-Silicone/dp/B0091A6AAY
    and lo and behold the squeak stopped. Since then I've hit the suspensions with pressure washer and lubed up everything with this stuff and i've been squeak free for about a week now so we'll see how long it lasts.
    So yeah that's my story/experience on how the "front end squeak" went for me. Just wanted to share my experience with and it if this helps anyone then that's awesome.
    TL;DR: "Front end squeak noise" ended up being lack of lubrication on LCA bushings not the rad cab mount bushings
    mistrchow and SR-71A like this.
  2. Nov 4, 2020 at 11:58 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    @ME OFF Rd might be worth a shot for you. Cheap and easy thats for sure.
    themanbearpig012[OP] likes this.
  3. Nov 4, 2020 at 12:00 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    If you do end up trying this I would recommend pressure washing the suspension before you spray it. Just to clean up and dirt and debris that may be lodged in anywhere
  4. Nov 4, 2020 at 12:00 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Also, O'reilly's has this smaller can of this stuff for like $8. Walmart has it too or at least should
  5. Nov 4, 2020 at 12:38 PM
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    Good to know and I'll keep this in mind but my issue is more of a popping noise. If I get my house button back up Thurs/Fri I'm hoping to put the Polyurethane Radiator bushing in this weekend.
    themanbearpig012[OP] and SR-71A like this.
