Squeaky front End
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, May 6, 2012.
  1. May 6, 2012 at 8:55 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Need help with my stock 06 single cab Tacoma with about 70k. My front end is kinda squeaky and was wondering how to fix the squeak. This only happens when I go over speed bumps. Thankyou
  2. May 6, 2012 at 9:01 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Check ball joints?
  3. May 7, 2012 at 3:48 PM
    pinktaco808
    can i spray something or gotta put the ball joint grease? any suggestion if that the problem
  4. May 8, 2012 at 10:36 AM
    pinktaco808
    up.im pretty sure it not the ball joint. it has to do with the upper suspension like th spring or the strut or something like that.
  5. May 10, 2012 at 10:06 PM
    pinktaco808
    any other help?
  6. May 13, 2012 at 10:32 PM
    pinktaco808
  7. May 13, 2012 at 10:39 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    hmm, control arm bushings maybe?
  8. May 14, 2012 at 9:29 PM
    pinktaco808
    upper and lower?
  9. May 15, 2012 at 9:34 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    My LCA bushings were squealing on my '09. I just sprayed them with WD-40 and the squeaking went away. It's been about 3 months since I did that.
  10. May 15, 2012 at 10:44 PM
    xpocad
    xpocad Well-Known Member
    Bryan
    San Benito Tx
    2012 DBL CAB TRD Sport 4x4
    3" Revtech Leveling kit 17" XD Addict Rims with -12 offset White Led dome lit interior Avid Light Bar 21" Blitz Pro Led Bar
    Do you have a lift? or spaces?
  11. May 15, 2012 at 10:45 PM
    xpocad
    Bryan
    San Benito Tx
    They installed my coils 180* backwards and the coil was squeaking on the sway bar.
  12. May 16, 2012 at 9:13 PM
    pinktaco808
    it all stock suspension
  13. May 24, 2012 at 2:36 PM
    pinktaco808
    found problem it was the front sway bar clamp part
  14. Dec 30, 2012 at 6:24 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Help name this part that squeaks...
    http://youtu.be/dnoD7tWsX68
    100%
