Squeaky front suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by smiller, Sep 17, 2010.
  1. Sep 17, 2010 at 1:23 PM
    smiller
    smiller [OP] New Member
    2004 tac dble cab 4x4
    First time poster here! I own a 2004 tac dble cab 4x4 and about 6 months after puchase i'm getting terrible squeaking from the front end. It seems like it may be the UPA bushings...(both sides?), anyone delt w/ this issue?
    thanks
  2. Sep 17, 2010 at 1:51 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    check the bushings for wear but also check the shocks to make sure they arent leaking or anything, are the springs relatively new? is it lifted? btw welcome to tw :)
  3. Sep 19, 2010 at 9:53 AM
    smiller
    It is lifted 6", but it was all done by previous owner. I will check the papers on how old things are. I sprayed the bushing with silicon, but that did not help at all. I'll dig in soon, i was just hoping to have someone say "yeah that happened to mine....do this and its gone!"
    thanks
  4. Sep 19, 2010 at 6:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is it a 6" suspension lift or a combo of body lift and suspension lift?
    If it is a 6" "drop bracket" suspension lift, what is the brand? Fabtech, Trailmaster, ???
