Squeaky front Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bonesaw01, Feb 11, 2021.
  1. Feb 11, 2021 at 11:33 AM
    Bonesaw01
    Bonesaw01 [OP] Active Member
    Zack
    2013 Tacoma Baja
    93B44713-1982-4834-AB61-3EF195038365.jpg Hello, I currently have the delta uca’s on my truck and they squeak really bad. All I know is that when it rains or I spray lube on them, it sometimes stops squeaking. I’ve heard I might have bad heim joints or the shocks need to be rebuilt. My shocks don’t look like they are leaking and I’ve soaked everything that moves with lube and I still can get the squeak to go away. Anybody have an idea of what it might be? Every little movement makes it squeak.
  2. Feb 11, 2021 at 11:51 AM
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    Do you still have your sway bar? Check to see if that is rubbing your CO. i recently go an alignment and they adjusted my caster and it began to rub.
  3. Feb 11, 2021 at 11:53 AM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    No, I removed my sway bar and I just recently got an alignment too.
  4. Feb 11, 2021 at 11:54 AM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Is there any type of g
  5. Feb 11, 2021 at 11:55 AM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Is there any type of grease or lube that can temporarily fix it?
  6. Feb 11, 2021 at 12:01 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    i use lucas red and tacky but tbh my delta joints haven't made a single noise since the day i put them on.
  7. Feb 11, 2021 at 12:02 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I think all those joints should be serviceable and/or replaceable if thats in fact the culprit.
    Playing devils advocate here - are you sure the UCAs are actually the issue? Also, it looks like you recently cranked a few more turns out of the coil overs. Did it make the noise before then? Looks like a lot of pre-load, but idk for sure about Icons
  8. Feb 11, 2021 at 12:04 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    I don’t think its my delta joint, I think the heim joint on the uca’s.
  9. Feb 11, 2021 at 12:06 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Yea it still made the squeak before I adjusted it, but I’m not sure if it’s the Uca’s, I just think it is
  10. Feb 11, 2021 at 12:08 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    I have 2 inches of preload, icon says not to go over that.
  11. Feb 11, 2021 at 12:09 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Doesn’t look like Delta joint to me or does the grease zero fit under that cap?
    you have quite a few heims there (UCA, pivots, shock top and bottom, LCA?) all of which may be squeaking
  12. Feb 11, 2021 at 12:20 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Yea, there is a grease fitting under the cap, but I haven’t tried greasing the shock top.
  13. Feb 11, 2021 at 12:21 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    The squeak sounds like it’s metal on metal.
  14. Feb 11, 2021 at 8:21 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Is It possible that the heim joints on my uca’s are bad
  15. Feb 11, 2021 at 8:45 PM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    If you are trying to isolate which pivot point is specifically generating the noise, you could soak one specific joint (both sides of truck) and test drive. Repeat, one more joint at a time until it stops. You did mention rain or lubing everything quiets it down (temporarily) right?
  16. Feb 11, 2021 at 9:11 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Replace the heims and grease the delta joints
  17. Feb 11, 2021 at 9:14 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    Yea, the rain will make it stop. But lubing it up won’t work anymore. So that’s why I’m not sure what it is.
  18. Feb 11, 2021 at 9:17 PM
    shift957
    Cacapon River, WV
    11 AC OR
    What are/were you using to lube it?
  19. Feb 11, 2021 at 9:37 PM
    Bonesaw01
    Zack
    2013 Tacoma Baja
    I was using super lube from the spray can
    SR-71A likes this.
  20. Feb 11, 2021 at 9:40 PM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    I had a squeak for a long time with my icons
    When I went to rebuild them one side had zero, nada, zip oil in it...not even a drop or greasy residue.
    rebuilt them and it pretty much went away.
    The only squeak I have now is I think the coils when they compress.
    SR-71A likes this.
