sQuEaKy iN rEvErsE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goingcamping, Aug 1, 2011.
  1. Aug 1, 2011 at 2:19 PM
    goingcamping
    goingcamping [OP] Well-Known Member
    Brett
    Colorado
    2007 Tacoma
    Custom body work...boat trailer came of hitch, hit tailgate and Rammed stick thru lower valance while towing boat....hmmm, Maybe I should get a new boat?!?
    I have developed a slight "Chirp-chirp-chirp" while reversing. It seems to be speed dependent (meaning it gets faster as I pick up speed in reverse). The noise does not exist while regular forward driving. I've searched the forums and have come to the conclusion it might be the U-Joints?
    This just started this past weekend after towing our camper 240 miles + or -.
    How hard are the U-Joints to replace? Are there better brands than Toyota?
    Thanks,
    ~GC
  2. Aug 1, 2011 at 5:34 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Sounds like a classic u joint squeak. Most likely a vibration also at speed better fix it soon.
  3. Aug 2, 2011 at 9:34 AM
    goingcamping
    Brett
    Colorado
    2007 Tacoma
    Thanks Maine! Doing it today!
  4. Aug 2, 2011 at 9:50 AM
    goingcamping
    Brett
    Colorado
    2007 Tacoma
    My first thought was also the carrier bearing, but after cruising TW I think it's more likely the u-joints?! I guess since I'm going to have it out I might as well replace both?
    It is not obvious which u-joint it is as both felt pretty solid upon first check? I will update when I figure it out!
    Ciao,
    ~GC
  5. Aug 3, 2011 at 12:28 PM
    goingcamping
    Brett
    Colorado
    2007 Tacoma
    Thanks to the few that responded!
    The squeak was the the forward most joint. The guy that removed/replaced them said there was one cap completely dry and was probably a matter of time before it failed. So, $88.00 later I have 3 new u-joints installed, put the shafts back in this morning...squeak gone. BTW, the carrier bearing from Toyota Dealership is $206.00...if needed the drive line place charges $100.00 installed.
    He also thought the it was in ok shape and did not recommend replacing it at this time. Pretty easy repair in the future!
    Ciao,
    ~GC
  6. Aug 3, 2011 at 12:31 PM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    Good to know! I have this problem on my 96 4runner.... sounds like it's the same problem. Thanks for the info!
