Squeaky leaf spring bushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muleyhunter, Jul 9, 2013.
  1. Jul 9, 2013 at 8:16 PM
    muleyhunter
    muleyhunter [OP] Git-r-Done
    Trevor
    Logan Utah
    07 2.7L 4x4
    Afe Pro dry cold air intake, lce header, dynamax super turbo muffler, scangauge II booming stereo
    So the front rubber bushing where my leaf spring attached to the truck pretty much sounds like a banshee from hell! It's only the passenger side where it attaches in front of the back tire.I pressure wash the underside of my truck on a regular basis. I've tried wd40, and other lubes but nothing will shut the stubborn thing up! Do I need to take the bolt out and grease it all up? Any suggestions?
  2. Jul 9, 2013 at 8:44 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    ive got the same issue...saw that a few places online had the bushing set for $15...that may be worth a shot
  3. Jul 11, 2013 at 12:04 PM
    Dizo
    Dizo Well-Known Member
    Oliver
    North of 62°, Canada
    2005 DCLB TRD Sport
    Aux Audio-input, 5100's @ 1.75", 2" Wheeler's AAL, LED Underhood Lighting, Anytime ABS-Off Switch,
    WD40 will just make it worse in the long run. Not a true lube, more of a penetrating fluid. Best bet is a new bushing - they aren't expensive.
