Squeaky Leaf Springs Question
Discussion in 'Hawaii' started by BronsDaGreat, Aug 4, 2014.
  1. Aug 4, 2014 at 3:52 AM
    BronsDaGreat
    BronsDaGreat [OP] Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    I get the Fabtech 6 inch lift with the AAL and blocks in the rear.. My leaf springs squeak like crazy! Anyone else dealing with this or now a fix? I lube constantly and that fricka still squeaks! Any suggestions?
  2. Aug 4, 2014 at 4:07 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Check and make sure you cut off the leaf brackets the metal C clamps near the ends
    [​IMG].
    I didnt when I installed my AAL and it squeaked all day
    With the AAL it should have come with new C clamps and if they overlap or the AAL touches the old ones it will cause a squeak
  3. Aug 4, 2014 at 8:42 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Pond liner between the AAL and the leaf pack.. get the thick stuff (which also means expensive) from lowes.. I've been meaning to put up a GB (just for oahu peeps) and split the roll. Its over $100, but you really only need a little 2 or 3 inch squares.. or you could cut a small strip and wrap...
    i haven't gotten around to it yet, but if you buy it and cut it up, I'm sure a couple guys would split it with you. Even 6 guys would be about $20 a person and you would have choke..
  4. Aug 4, 2014 at 8:49 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  5. Aug 4, 2014 at 8:50 AM
    geekhouse23
    I have sold some strips to members here :anonymous:
    Have some still if interested..
  6. Aug 4, 2014 at 11:32 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    I not sure if the clamps were cut. Maui off road did em. Newbie question but which leaf is the AAL? Is it the top one? I got to find this damn squeak!!! I going check out lowes. Mahaloz guys.
  7. Aug 4, 2014 at 12:19 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    the bushing eye's may need to be greased as well.
    mine squeak occasionally and I've oiled and used some rubber material.
  8. Aug 25, 2014 at 11:31 AM
    Ben550
    Ben550 Well-Known Member
    2012 TRD OFF ROAD
    I saw one guy stuck cut up bike tire tubes in between his springs. He said that worked. I was thinking of giving that a try. The squeak is very irritating.
  9. Aug 25, 2014 at 11:34 AM
    geekhouse23
