Squeaky Leaf springs while in SoCal?
Discussion in 'Suspension' started by medic, Jun 15, 2009.
  1. Jun 15, 2009 at 8:11 PM
    medic
    medic [OP] Active Member
    Arizona
    09 DC LB 4x4
    Front: Icon 3" lift, Total Chaos UCA's. Back: Bilstein 5100's w/ AAL's
    I recent returned from SoCal, and while I was there, my leaf springs squeked and creaked like crazy. Anyone ever have this problem or know how to fix. Now that I am back in Arizona, all is fine. :notsure:
  2. Jun 15, 2009 at 8:26 PM
    usctacoma
    usctacoma Be a thinker, not a stinker
    Columbia, South Carolina
    05 PreRunner SR5 Doublecab
    Tint, Black Badges, Firestone Destination 265-70-17s, Weathertech Floor Liners, Sockmonkey decals, Flowmaster 40, Defiant light bar, 4 5" PIAA 540s, BHLM, 5100s @ .85, eibach springs, 1/4" Toytec spacer, 2" Toytec AAL, painted grill, UWS tool box
    mine just started squeaking too about a week ago. i haven't done any offroading or anything out of the ordinary to possibly do any damage. I don't know whats causing it.
  3. Jun 15, 2009 at 8:27 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    mine squeak whenever I hit a dirty puddle (or turn my truck into a submarine). Try to pressure wash the hell outta them
  4. Jun 15, 2009 at 8:32 PM
    usctacoma
    I'll definitely try that because its quite annoying.
  5. Jun 15, 2009 at 8:42 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    x2 pressure wash the crap out of them.
  6. Jun 15, 2009 at 8:57 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i had mine submerged in mud and they've squeaked ever since. tried pressurewashing them, and it helped a little, but they still squeak...so i'll be dissassembling mine to clean them when i get the time.
  7. Jun 15, 2009 at 9:01 PM
    DanGer
    Whatever you do, keep WD 40 away!
  8. Jun 15, 2009 at 9:04 PM
    bajamoon
    STEVE
    Whittier
    why not wd-40.
  9. Jun 15, 2009 at 9:05 PM
    medic
    Arizona
    09 DC LB 4x4
    Mine only squeaked while down in SoCal. Back in Arizona now and all is well. What gives? Why?
  10. Jun 15, 2009 at 9:10 PM
    bajamoon
    STEVE
    Whittier
    cali dirt and az dirt don't get along.:notsure:
  11. Jun 15, 2009 at 9:10 PM
    DanGer
    It actually attracts dirt in the long run and gets all that gunk stuck in there.
    I have no idea why in AZ it stopped
  12. Jun 15, 2009 at 9:16 PM
    bajamoon
    STEVE
    Whittier
    ya have noticed that, wd-40 doesn't do anything to keep the leaft quiet anyway, maybe it has something to do with the heat, cali has been cool the last few weeks and i am sure az has been 1000'f like it always is, maybe the bushings soft and give more in the high heat and get harder and create friction in cooler temps.:notsure:
  13. Jun 15, 2009 at 9:21 PM
    medic
    Arizona
    09 DC LB 4x4
    Best answer I have heard yet..... albeit the only one.
  14. Jun 15, 2009 at 9:22 PM
    medic
    Arizona
    09 DC LB 4x4
    Although it has been cooler in Arizona than the past years at the same time.
  15. Jun 15, 2009 at 11:05 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Silicone lubricant spray. Spray the bushings and pads between the leafs. Use a screwdriver to wedge between the leafs so you can spray the pads between the leafs.
  16. Jun 15, 2009 at 11:12 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    pressure wash and spray in between with a good moly lube... triflow works real good... i'ts basically liquid teflon
  17. Jun 15, 2009 at 11:30 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Could it also maybe be the shocks mine just started to do this as well and I barely push on the truck even just a little bit and squeeks everytime. Or just the bushings for the shocks or leafs.
  18. Jun 16, 2009 at 6:08 AM
    bajamoon
    STEVE
    Whittier
    it won't be the shocks, it is either the bushings or the pads on the leafs. Go to a do it yourself car wash clean the crap out of them, then go home and lube the pads really good and hope that works.
  19. Jun 16, 2009 at 8:29 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    Here is the solution:
    I had the same issue with my 09. it drove me crazy! the anti friction pads wear out between the leaf springs. i took it to the dealer and They re greased the leafs at no cost, and now no problems at all ! Its not a tsb, but something similar. The service guys were the ones that told me about it.
  20. Jun 16, 2009 at 9:26 AM
    bajamoon
    STEVE
    Whittier
    I would go to the dealer but tossed the stock leafs away a long time ago, running deavers now, pressure wash and lube the pads works best.
