Squeaky leaf springs???
Discussion in 'Suspension' started by TacoTony, Jul 10, 2013.
  1. Jul 10, 2013 at 10:45 PM
    TacoTony
    TacoTony [OP] Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Ok well I had an aal but took it off because it was squeaking, now I can't move my truck without the leafs squeaking
    Has anyone else ever had this problem ?
  2. Jul 11, 2013 at 12:55 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Are you sure it is the leaf springs? Make sure the Center Pins are tight, and that the u-bolts are torqued down properly.
  3. Jul 24, 2013 at 7:12 AM
    taco Josh
    taco Josh Member
    josh
    se Okc,ok
    06 tecoma quad cab 4x4 silver V6
    I'm having the same problem my leaf springs squeak like crazy and I talk to the dealer ship about it and they make a $40.00 fix for it. just looks like 4 rubber disk
  4. Jul 24, 2013 at 7:17 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes , apparently they work
  5. Jul 24, 2013 at 9:59 AM
    xollox
    xollox Member
    Philadelphia, PA
    09 Silver I4 AC
    The factory rubber disks solved my non-tsb leaf squeaking.
  6. Jul 24, 2013 at 10:50 AM
    taco Josh
    taco Josh Member
    josh
    se Okc,ok
    we're they hard to install don't have a lot of tool and can't see paying the dealership 180.00 to install a 40.00 set of rubber disk
  7. Jul 25, 2013 at 5:17 AM
    xollox
    xollox Member
    Philadelphia, PA
    09 Silver I4 AC
    It took me about 15 minutes using the stock jack, a big screwdriver (to get the leaves apart) and a cheap HF pry bar (to spread the leaves further.) Not hard at all.
  8. Jul 25, 2013 at 5:21 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
  9. Oct 22, 2013 at 11:46 PM
    stumblestacks
    stumblestacks Well-Known Member
    North lake Tahoe
    Beat up 98taco 3.4L limited xtracab TRD
    Finally blew the motor at 230,000, sprung for a Jasper with 100,000/3 year warranty. The birdpig has a new set of wings! OME heavy load lift kit, Dakar leafs w/AAL, frame mounted energy suspension 4.5" bumpstops, 882 coils, nitrocharger sport shocks, trail gear sliders, addicted offroad front bumper, KC 130w daylighters, Warn M8000, 31" BFG KM2's, custom dents and Nevada pinstripes.
    I've gotten the squeak with all 3 of my sets of OME Dakars. I've read a lot of great ideas. One of the best and probably the one that will last the longest is to take the leaf pack apart and paint it with graphite powder mixed with paint. Too much work for me, but it inspired my solution, which seems to last for about 6 months. I high lift my rear till the axle is at full droop and the leafs are spread out (safety first, or second, since using jack stands would be safety first, put it in 4 low, in reverse, and block the front wheels front and back),pressure wash between the leafs and in the shackles. Let it dry and blow it out with a compressor. Get a bunch of spray cans of dry film graphite powder lube with the little plastic straw and spray it between the leafs and all over the shackles. Let it dry and do it again. Let it all dry before you drop the jack. Silent for months and none of the dirt grit and sludge buildup that you get with grease and oil-based lubricants. I love that dry graphite powder lube. I use it on my winch fairlead, all over my mt bike, and spray it in the keyholes on my doors, camper shell, ski racks, and bike locks. Repels water, ice, and dirt. Cheap too. Napa dry film graphite lube #1413. Make sure not to get #1412. The can looks the same but it's "wet film graphite lube". Wet = a bunch of grime stuck to your shit.
  10. Oct 22, 2013 at 11:52 PM
    OZ-T
    Peter North
    British Columbia
    Have you tried the EPDM strip fix for squeaky Dakars in the Squeaky Dakar thread ?
