Squeaky Leaf Springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 423taco, Dec 23, 2016.
  1. Jun 13, 2017 at 4:55 PM
    #101
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    That was more for the person who was implying this was a "3rd gen Toyota quality going down the toilet" comment.
    I'll go back to my point. For the amount of your messages I've seen in this thread, you could have spent less time remedying squeaky leaf springs throughout the life of your truck, applying White Lithium grease. "Problem" solved.
  2. Jun 13, 2017 at 5:15 PM
    #102
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    White lithium grease is not the best solution.
  3. Jun 13, 2017 at 5:16 PM
    #103
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    You mean to tell me grease attracts dirt?
    smitty99 likes this.
  4. Jun 13, 2017 at 5:17 PM
    #104
    toyotatacomaTRD
    Why? I'm on 12 years with my truck. It takes me maybe 1 minute a year total to remedy this "problem". I'm also on the same $6 can.
  5. Jun 13, 2017 at 5:17 PM
    #105
    Northern Taco
    Off-road often?
  6. Jun 13, 2017 at 5:17 PM
    #106
    smitty99
    Scottsdale
    Toyota engineers recommend clean and do not lube. See the tech tip. Use search function.
  7. Jun 13, 2017 at 5:18 PM
    #107
    toyotatacomaTRD
    So my 12 years experience doesn't have any bearing on this conversation?
  8. Jun 13, 2017 at 5:19 PM
    #108
    smitty99
    Scottsdale
    Only for you. It's anecdotal otherwise.
  9. Jun 13, 2017 at 5:21 PM
    #109
    Northern Taco
    The trouble with oil based lubricant is if you use the truck on dirt roads it's attract lots of dirt and grime
  10. Jun 13, 2017 at 5:23 PM
    #110
    toyotatacomaTRD
    Tacomaworld has changed in the 7 years I've been on here. Granted I barely read it like I did. However, it used to be a place where people would offer solutions. The threads I'm reading seem to be people just complaining. Not wanting to help and more inclined to point fingers. The only reason I'm in this thread was to offer solutions. Majority of comments are just people complaining. It's really too bad.
    Monster0Frankenstein likes this.
  11. Jun 13, 2017 at 5:30 PM
    #111
    Northern Taco
    I think people would be more inclined to take advice/tips if their truck wasn't new. I regularly look on these forums for solutions to issues I may be having with my 12 year old truck, but if I was having issues with my new 4Runner I'd expect toyota to remedy them. That's just my take
  12. Jun 13, 2017 at 5:32 PM
    #112
    smitty99
    Scottsdale
    If you want a solution read my write up below specifically the part regarding energy suspension grease. But since you already have it figured out you shouldn't need to waste your time?
  13. Jun 13, 2017 at 5:53 PM
    #113
    toyotatacomaTRD
    Is there a link to the write up? I don't see it. I would definitely read it.
  14. Jun 13, 2017 at 6:02 PM
    #114
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    My truck was silent for 30K miles. Rain snow, dirt, mud, and obviously lots of pavement. Then I loaded it with 1100 lbs of concrete blocks and drove a few miles of dirt. A few days later it was squeaking like crazy. I sprayed silicon spray between the leaves (assuming that would not attract dirt like grease or oil). Within a few blocks it was silent. Then I did another 1/2 ton concrete run in the dirt, and the squeaking is back. Doesn't really bother me too much, but as others say a $35K truck should be quieter. And my 200K mile T100 was silent.
  15. Jun 13, 2017 at 6:08 PM
    #115
    smitty99
    Scottsdale
  16. Jun 13, 2017 at 7:07 PM
    #116
    toyotatacomaTRD
    I saw a write up, I didn't see yours. After reading, it still doesn't appear there's a one time, end all solution. My solution works pretty dang good. If you have a problem with dirt building up (which I haven't in 12 years), wash it off. It's been mentioned before in this thread, this issue isn't limited to Tacomas. You'll find it's actually pretty common. I guess the moral of the story here. Sit around, complain that Toyota didn't issue a fix immediately. Or take the solution most have found simple, easy to do at home, lasts a long time.
  17. Jun 13, 2017 at 7:44 PM
    #117
    smitty99
    Scottsdale
    You do you boo boo.
  18. Jun 13, 2017 at 7:47 PM
    #118
    toyotatacomaTRD
    Still waiting for your write up.
  19. Jun 14, 2017 at 4:18 AM
    #119
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    You're putting some pretty strong faith in the same engineers that gave you squeaky leaf springs, howling diff, busted trip, vibrating driveshafts, shitty shifting, failed cps sensors, etc.
    Strong logic you got there.
    tacocat_2019 likes this.
  20. Jun 14, 2017 at 4:21 AM
    #120
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Lol I've been turning wrenches long enough to know a blowhard when I see one. I would take a big grain of salt with any Smitty write-ups.
    tacocat_2019 and The hammer like this.
