squeaky leaf springs
Discussion in 'Suspension' started by 4ari trd, Nov 29, 2009.
  1. Nov 29, 2009 at 6:23 PM
    4ari trd
    4ari trd [OP] Well-Known Member
    portland, oregon
    08 trd sport double cab long bed
    cat back magnaflow exhaust- stage 2 k&n intake- URD MAF Sensor Calibrator, Westin bull bar, black housing headlights, yellow fogs, 10000k hid, fog light mod, 3in tuff country lift
    I hate how when its dry something in my rear end is always squeaking...I dont know what it is some body said it was the leaf springs..I tried all kinds of lubes and sprays and it wont go away so i need help....
  2. Nov 29, 2009 at 6:25 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Dude, I ended up having to swap out my leafs. Try jacking it up and letting the wheels hang to open up your leafs and then spraying them out with a high intensity water hose.
  3. Nov 29, 2009 at 6:25 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Most likely it is the springs. You can wedge a screwdriver between the springs and pull out the silencer pads. Then clean them up, lube them with a good grease, and reinstall them. There are four pads per a leaf pack, eight total.
  4. Nov 29, 2009 at 6:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    first...you need to pressure wash them real good, then use a dry moly type lube and spray between each spring and the anti friction pads..spray them real good too.
  5. Nov 29, 2009 at 6:26 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    I had this problem on the drivers side. Got the TSB done and hasn't made a sound since
  6. Nov 29, 2009 at 6:35 PM
    4ari trd
    portland, oregon
    Is it hard to take out the silencer pads?
  7. Nov 29, 2009 at 6:44 PM
    Jason'sLawnCare
    No. You just need a big screwdriver and a hammer. maybe some pliers to help remove the silencer pads if the screwdriver isn't big enough to squeeze your fingers in there. Maybe you could use a pry bar.
  8. Nov 29, 2009 at 6:55 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    Just turn up the radio, F%$K it. Mine squeak too but i dont worry about it.
  9. Aug 29, 2010 at 7:07 AM
    StarGazer
    StarGazer Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    I used "Simple Green" to clean the pads and space between the leafs. Then I sprayed the pads and in between the leafs w/ "3-in-One" high-performance lubricant spray that I bought @ Autozone. I did this from another mod somewhere in here. I did this 6-26-10 and still I'm squeaky clean (or no squeak).
    I had to use my jack on my hitch to get my truck high enough.
    The spray I used.
    I marked my pads w/ "white out" to remember which direction they go in.
    Where my pad goes. Or came from.
    This is a very simple procedure and like I said on top, I've been squeak free for three months. Drove 826 miles towing a TT through lots of rain and been driving it in above 100 degree weather around town here in Frisco, Tx.
  10. Aug 29, 2010 at 11:13 AM
    4ari trd
    portland, oregon
    Thanks for the sweet write up. I'll give it a shot.
