Squeaky Leaf's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aztacotrd, Jan 1, 2011.
  1. Jan 1, 2011 at 7:22 PM
    Aztacotrd
    Aztacotrd [OP] Well-Known Member
    Austin
    Az
    O8' V6 Prerunner Accesscab
    So i was out offroading with my dad this weekend and got a bunch of mud on my truck... The next day when i woke up to go and wash my truck my leafs were really squeaky.. So after i cleaned it and sprayed the leafs the truck seemed to be fine and then i woke up today and they were squeaky again! Just took it to a power sprayer and cleaned'em up hopefully that will help. Anyone else had this problem? And if so what are some good fixes for it?
  2. Jan 1, 2011 at 7:30 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    There's a write up on them. Putting rubber in-between the leafs. I may try some rubberized roofing tar and rubber from a mud flap to keep the pieces in the leafs.
  3. Jan 1, 2011 at 7:30 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Common problem...temp fix is to jack up the rear by the frame, pry open the leafs and squirt some grease in between the leafs. Look for a DIY in the stickies.
    Toyota also has replacement nylon pads.
  4. Jan 1, 2011 at 7:46 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
  5. Jan 1, 2011 at 7:53 PM
    Aztacotrd
    Austin
    Az
    Ya i saw that thread from an earlier search but i'm just wondering why it would start right after i finished offroading?
  6. Jan 1, 2011 at 8:07 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This happens to mine after they get dirty and I rinse them out really good. I usually just spray a little grease between the leaves and it goes away until the next time I go offroading and get them dirty then have to clean them again.
  7. Jan 1, 2011 at 8:12 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    This is exactly what I've done, I use Mobil 1 synthetic grease and it hasn't squeaked in a few months.
  8. Jan 1, 2011 at 8:12 PM
    Aztacotrd
    Austin
    Az
    O alright so atleast i'm not the only one haha so what type of grease should i use?
  9. Jan 1, 2011 at 8:16 PM
    macgyver
    Brad
    Canton, GA
    I either use wd-40 or white lithium grease, whatever I have on the shelf in my garage.
  10. Jan 1, 2011 at 8:20 PM
    Aztacotrd
    Austin
    Az
    Awesome i'll have to try this out tommorow and post up the results
