Squeaky passenger seat..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, May 27, 2010.
  1. May 27, 2010 at 10:38 PM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    Any idea on what I should try lubing?
  2. May 28, 2010 at 3:48 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Sounds like you and your girl need to use the other seats.;) JK. Might try spraying some WD40 on the springs under the seat.
  3. May 28, 2010 at 3:56 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    i believe there is a TSB on this issue.
    TSB 0288-08 for the squeaky seat. Here it is from mechanic at toyota:
    R/R LH FRONT SEAT TRACK PINS TSB ~|~CUSTOMER STATES CHECK DRIVER SIDE FRONT SEAT MAKES NOISE WHEN SITTING ON IT ~|~F ~|~2000 CHECK DRIVER SIDE FRONT SEAT SQEAKS-DUPLICATED AND FOUND SERVICE BULLETIN 0288-08 REMOVED PINS AND ALL OK NOW
  4. May 28, 2010 at 2:30 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    Sorry to sound like an idiot, but what exactly does TSB stand for? I thought it was just for the springs underneath the rear end of the truck.
  5. May 28, 2010 at 2:32 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Technical
    Service
    Bulletin
  6. May 28, 2010 at 2:32 PM
    LVTacoma
    LVTacoma Well-Known Member
    just put some Corbeau Baja SS's in it now!
  7. Jan 9, 2012 at 4:42 AM
    staplegun
    staplegun New Member
    Had this issue and gleaned the net. At any rate, what I found was that the four seat cushion bolts (12mm) were loose. I had taken this seat apart less than ten months ago and tightened and found out they loosened again. I removed, again yesterday, and re-tightened - I added Loctite blue (242) and the squeak is now gone. Don't start hacking the pins without checking these seat pan bolts first. My trunk - 1997 Tacoma.
