Squeaky Power Windows
Discussion in '3rd Gen. Tacomas (2016-2023)' started by quikrain, Apr 22, 2019.
  1. Apr 22, 2019 at 10:31 AM
    quikrain
    quikrain [OP] Well-Known Member
    2017 Red Tacoma TRD SP DCLB
    My trucks been doing this from day one pretty much. Just about everytime I roll my windows down they squeek. Is this happening to everyone else? Is it an easy fix?
    tcjacado likes this.
  2. Apr 22, 2019 at 10:33 AM
    Savoia
    Savoia Well-Known Member
    Ray
    2018 Quicksand Tacoma TRD Sport 4x2 DCSB
    Mine usually only squeaks when it's dry and hot outside. I'm in for a solution tho
  3. Apr 22, 2019 at 10:35 AM
    quikrain
    I'm guessing it's able to be "lubed" (like sunroof) just not sure what kind or what points might need greased.
    Savoia likes this.
  4. Apr 22, 2019 at 10:39 AM
    Savoia
    Ray
    My exact thought, but I feel like any lubricant put on the windows will leave traces when put down and back up
  5. Apr 22, 2019 at 10:41 AM
    tcjacado
    tcjacado Well-Known Member
    Mine used to do this also.. only thing I have done to make it stop is time.
  6. Apr 22, 2019 at 10:42 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Not sure what particular noise you're hearing, but we used air to blow out the window slides & then used dry silicone lubricant spray to lube them at the shop I worked at. Helped the windows go up quicker
  7. Apr 22, 2019 at 9:19 PM
    tcjacado
    It's the window seal that runs along the bottom on the door
  8. Apr 23, 2019 at 7:03 AM
    AKGSD
    Joe
    Alaska
    Ah, yeah, mine makes nasty scraping noises - seems to pick up dirt immediately and then scratches the glass with it. I'd just roll the window down and clean the seal where it contacts the glass
