Squeaky Rear Brakes 14,000 miles
Discussion in 'Technical Chat' started by ColoradoTaco, Aug 17, 2013.
  1. Aug 17, 2013 at 5:58 PM
    ColoradoTaco
    ColoradoTaco [OP] Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    Brakes are squeaking ecspecially once it hits the 5mph or below mark. Took to dealer there no help. unless I want to spend money. What could be the causes of this? The dealer said there was a lot of brake dust and cleaned them. Still squeaking....at 14,000 is this a warrenty issue? any ideas/suggetions to fix this.
  2. Aug 17, 2013 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    you can cycle the parking brake on/off a about 6 times, and that helps set the adjustment.
  3. Aug 17, 2013 at 6:11 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    Mine took 3 trips to the dealer to correct. 7K miles
    1st time they cleaned the drums.
    2nd time they machined the drums. The entire truck shook like a washing machine when I braked.
    3rd time they replaced the drums and shoes. The new drums have a teflon liner betwen the the drum hat and the axle flange.
  4. Aug 17, 2013 at 6:58 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    Thanks Chris I will give it a try.
    I hope it doesn't come to this was it all warranty work or did you get the dealer shaft?
  5. Aug 18, 2013 at 7:30 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    There's a TSB for some trucks -- T-SB-0236-12
    Have the dealer check and see if it covers '13's as well. I know it covers my '12.
  6. Aug 18, 2013 at 7:38 AM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Yep, my started squeaking under the 5mph mark and had the tsb done to my truck a few months ago, squeak free. They replaced the drums and shoes.
  7. Aug 18, 2013 at 3:28 PM
    gasgasman
    Girard
    Texas
    Yeah, it was warranty.
    Funny thing is, they changed my e-mail address on the repair order. They thought I would burn them on the CSI survey. Since it took so many trips to get it fixed.
    Now I don't get e-mails for when I need my oil changes done.
  8. Aug 18, 2013 at 3:54 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Squeaky brakes and leaf springs are completly normal for these trucks... if they didn't squeek you'd have a problem. :rolleyes:
