Squeaky springs at 5K miles.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DonNH, May 11, 2014.
  1. Aug 26, 2014 at 6:37 PM
    DonNH
    DonNH [OP] Well-Known Member
    Don
    Southern NH
    90 xcab>01dcsb>14dclb sport
    When mine were squeaking I couldn't tell just where the noise was coming from. Had it continued (or if it starts again) I'd get some help to push on the bumper while I crawl under to isolate the location. So far, so good.
  2. Aug 26, 2014 at 6:53 PM
    thalgott3
    thalgott3 Dogs like trucks.
    Colin
    C-bus, OH
    '13 PreRunner SR5 DCSB
    Devil Horns & N-Fab Rock Rails
    My 2013 has the squeaks on the front suspension. It is super annoying and the dealership is also telling me that they cannot hear it. I will be taking them for a test drive at my next service. Anyone else have the front end squeaky suspension?
  3. Aug 26, 2014 at 7:37 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    i've never heard any squeaks out of my 2009.
  4. Aug 26, 2014 at 7:46 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  5. Aug 26, 2014 at 8:06 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I do, mostly on the passenger side. I had it back to the dealer for it once and they said no issue found, it squeaks over every bump or when the body leans. My 3 leaf pack used to squeak bad but now my TSB pack is quiet for now,
  6. Aug 27, 2014 at 6:27 PM
    thalgott3
    Colin
    C-bus, OH
    I work in project management for a heavy highway construction company and my Taco drives through rutted subgrade nearly every day. It is embarrassing driving up to the construction trailer every morning with the suspension sounding like a 20 year old motel box spring... :frusty:
  7. Aug 27, 2014 at 6:42 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I agree with you on that, I have been under the thing multiple times moving parts rocking back and forth and cannot figure out what the issue is. I almost want to say it is the shock causing the squeak.
  8. Sep 7, 2014 at 2:01 PM
    leew
    leew Well-Known Member
    massachusetes
    2006 Taco SR5 4x4
    I just had my frame replaced on my 2005 and the new leaf spring shackles make a lot of noise where the bolts go through. If I spray them with white lube it will go away for a little while. As soon as I can I will get under there and see if the shackle bolts are to tight or to loose.
  9. Nov 6, 2014 at 4:41 PM
    leew
    massachusetes
    2006 Taco SR5 4x4
    Thanks for the info, I didn't re torque the u bolts yet but no luck with the shackles. The noise seems to be coming from the shackles still and if you push down on the bumper the spring wont return to it's original position...
