Squeaky steering, lifted truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AFButters, May 12, 2011.
  1. May 12, 2011 at 3:09 PM
    AFButters
    AFButters [OP] Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    Just like title says truck is squeaky when making turns started a couple weeks ago, 28k miles
  2. May 12, 2011 at 3:14 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Hmmm
    Could be the pump? Could be the wheel bearings? Could be the CV joints?
    - Does it happen immediately as soon as you start to turn or later on in the turn?
    - Is it persistent or intermittent?
    - Does if happen when you turn the steering wheel to "full lock"?
    - Is it really a squeak, or is it more of a "creaking" sound?
    More details please.
  3. May 12, 2011 at 7:34 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    more of a creaky sound.. and i notice more when im sitting stopped.. and dont really notice it when im driving bc of road noise.
  4. May 12, 2011 at 8:29 PM
    mountainwolfpup
    Vancouver, WA
    OK, that's what I suspected. Unfortunately that widens the possibilities. Everything from your cab seat to the rear springs can make that sound.
    Can you answer the questions I posed in my last quote? I need to determine which system is causing the noise, then why.
  5. May 13, 2011 at 4:38 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I can sit and play with the wheel and turn it back and forth and it makes the noise.
    I also notice its creaky stepping on the sliders to wash the roof.. thinkin its the OME shocks
  6. May 13, 2011 at 4:55 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    What kind of UCA do you have?
  7. May 13, 2011 at 4:58 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Mine too, I just deal with it.
  8. May 13, 2011 at 5:00 PM
    JoeTacoma02
    Hmm...OP record a video with the sound and post it :)
  9. May 13, 2011 at 5:50 PM
    mountainwolfpup
    Vancouver, WA
    Yeah, from what you describe I guess I'd lean towards the shock springs or the UCA? That diagnosis is based on your truck making the sound when you're on the steps also... If that's the case it's not a concern, maybe annoyance but not a concern.
  10. May 24, 2011 at 2:35 PM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    Check your lower ball joints mine is doing the same thing and I found out my driver side has seized up going to replace them with greaseable ones.
  11. May 24, 2011 at 2:39 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    It's due to you being a Caps fan OP .
    Nothing good can come of that .
    Canucks FTMFW Bitches .
