Squeaky Suspension in front
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pnicholas1019, Nov 1, 2011.
  1. Nov 1, 2011 at 6:52 PM
    Pnicholas1019
    Pnicholas1019 [OP] Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    I have a bad squeak coming from the front suspension. I wen wheelin a bit and it sounds like its wworse. Dirty?? What should i do to quiet this annoting noise. Turning or even really drivin i cant stand it help me out guys!! -_-
  2. Nov 1, 2011 at 7:08 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    Sorry, I don't know what to tell you. Mine does the same thing after wheeling and I can't locate where it is coming from. Mine went away after a while, the the next time I drove in the mountains the noise came back for a while and went away again.
    A few times a have had things stuck in the brakes and it was making a bad squeeking noise. After backing up it went away.
  3. Nov 1, 2011 at 7:10 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Try putting some WD-40 on the lower strut bushing
  4. Nov 1, 2011 at 11:04 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    I having the same problem right now with my Camburgs. I just lubed the UCA ball joint and hoping it'll be good to go tomorrow.
  5. Nov 2, 2011 at 4:11 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Check ball joints. If any look dodgy at all, then replace. If a ball joint fails while you're driving a lifted truck, chances are it'll go ass over tea kettle.
    Also...OP you have a pickup not a Tacoma. Just a clarification. Still an awesome truck though, it's just a little different than the 1st gens.
