Squeaky Suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sbarnard2086, Dec 2, 2021.
  1. Dec 2, 2021 at 7:54 PM
    sbarnard2086
    sbarnard2086 [OP] Member
    Seth
    2016 Tacoma TRD Off-Road
    2in ARB Old Man Emu lift
    Hi everyone -
    Put a new 2” old man emu lift on my truck a few months back and I’m noticing a little squeaking. Not sure if it’s somewhat normal or not. It bugs me lol. Took it back to the shop and had them check it but they said everything looked ok.
    I bounced on the bed and it does squeak and I bounced on the bed of my dad’s 06 Ranger that he has as a beater truck and it didn’t make any squeaking. I’m just wondering if maybe the lift is shot, or the shop did something wrong, or if that’s just how it is. I’m planning on taking it back to the shop on an off day from work and show them what it does, but thought I’d get some other opinions first.
    Thanks!
  2. Dec 2, 2021 at 8:00 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    You probably have some rust in between the leaf springs making noise. If you use these they won't squeak ever again. Only problem is that the springs will have to come off the truck and this product needs to be cut and fit between each spring. You'll need two of these, I did it on my tacoma and squeaks were gone.
    https://www.speedwaymotors.com/Leaf-Spring-Liner-with-Lip-2-Inch,39861.html
  3. Dec 2, 2021 at 8:01 PM
    AntiStupid
    AntiStupid Member
    Luling, LA
    2018 Tacoma TRD OR 4x4
    Years of reviews on the OME include a majority of complaints about squeaks. So much so, that on the OME webpage, they have a disclaimer.
    I didn't experience any squeaks until completing my last trip to the Ozarks. They squeak with any movement of the truck now. I sprayed them down with lithium grease, but it hasn't helped.
    BUT, I knew they would prob squeak when I bought them, as I read hundreds of reviews.
  4. Dec 2, 2021 at 8:10 PM
    sbarnard2086
    Seth
    Ah, bummer - I did read some reviews but didn’t see any about squeaks ‍♂️
    It rides just fine and all that but I do notice the squeaks from the front and back. I’ll check out the stuff y’all mentioned though - maybe it’ll help some. Appreciate it y’all
  5. Dec 2, 2021 at 8:13 PM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Double check the width of your springs... mine were 2" and worked great for my leaf pack. If you go that route come back and tell us how quiet the springs are ;)
  6. Dec 2, 2021 at 8:18 PM
    sbarnard2086
    Seth
    Yeah definitely - will do for sure
    TXTaco13 likes this.
  7. Dec 2, 2021 at 8:20 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    It might be something simple too - if your spare tire is slightly loose, it'll produce a squeak. Check to make sure it's tight and you may have solved the problem.
  8. Dec 2, 2021 at 8:26 PM
    sbarnard2086
    Seth
    Good idea - will definitely check it. Thanks
  9. Dec 2, 2021 at 8:32 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Mine have been squeaking since i got it a few years ago, I'm just too lazy to care. Most of the time i drive with music on and windows up.
  10. Dec 2, 2021 at 8:36 PM
    sbarnard2086
    Seth
    Lol yeah I do too but when I first got it installed it didn’t squeak at all but then started it outta nowhere. If it comes down to it, like there’s not an inexpensive fix, and nothing is being damaged, I’ll probably just live with it too
  11. Dec 2, 2021 at 9:20 PM
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    In the middle of each of the round isolator pads on the rear leaf springs there are small holes on the bottom. You can pump grease into the pads with a grease gun and needle greaser. Just did this on mine today to get rid of a squeak in the rear. I suggest pressure washing the leafs before hand if possible.
    sbarnard2086[OP] likes this.
  12. Dec 2, 2021 at 9:21 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I’ve got a toytec add a leaf gradual pack. Which is like a mini leaf pack on your leaf pack. It’s a little extra squeaky. It makes me laugh sometimes. But it would be nice to have a little stealth in my movements.
