Squeaky Suspention
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tyler_G13, Mar 28, 2010.
  1. Mar 28, 2010 at 9:34 AM
    Tyler_G13
    Tyler_G13 [OP] Well-Known Member
    Tyler
    Texas
    08 PreRunner Texas edition
    Custom Black Leather Borla Exhaust system fold-away bed cover 20" Tx Edition chrome rims Alpin INA-W900 double-din touch screen chrome running bars 35% tinit front/16% tint back python alarm system 1 13TW5 JL audio subwoofer custom ported subwoofer box powered by JL Audio HD750 amp Lots of Hush Mat on back wall
    Does Anybody else seem to have really squeaky suspenision, i think mine is coming from the rear? Or Does anybody know why that would be happening?
  2. Mar 28, 2010 at 9:39 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Happens on occasion. Rinse thoroughly with high pressure water, let dry, and then apply some graphite or teflon lubricant if needed (you can get spray stuff from Lowes...DuPont makes a good one...)
    Avoid WD-40 or other oil based lubes...they *attract* and *collect* dirt/gunk.
  3. Mar 28, 2010 at 9:43 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    ^^ what he said. If that doesnt work you will have to separate the leaf springs and lub the friction pads with some GP grease.
  4. Mar 28, 2010 at 11:53 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    WD-40 worked for me... I just sprayed the leaves and the noise went away. That was about a year ago and it hasnt come back.
  5. Mar 28, 2010 at 11:59 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2 on my first gen
  6. Mar 28, 2010 at 12:13 PM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    It's most likely your leaf springs making most of the noise. It's from all the sand and dirt stuck in the existing grease. I've greased mine before but didn't bother cleaning them too so the squeaking came back quickly.
    Does WD-40 really work? That seems so much easier than tearing the leafs apart.
  7. Mar 28, 2010 at 12:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    WD-40 will work...but it will also trap dirt inbetween the leaves and in the centering pin.
    Not a huge deal-but I can contribute to the issue. If you drive in dusty or muddy conditions- It can make a mess. WD-40 is also a water displacer...SO cleaning the old gunk out can be a bit harder.
    If it works for you- Great. Go for it. I wouldn't recommend it tho. Specially not if you have rubber bushings that are squeaking.
  8. Mar 28, 2010 at 12:19 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    There is a Technical Service Bulletin on 05 tacomas (maybe other years) for the leaf springs being overly squaky. They claim its caused by those rubber bushings. And the only way to truely "fix" it is by taking the leafs completely apart and cleaning/greasing them. And that only lasts until it starts squeaking again.
  9. Mar 28, 2010 at 12:24 PM
    NAYo2002
    Great Falls, MT
    Worked perfectly for me... it was almost too easy. My problem seems to be from either dirt or surface rust issue. I sprayed WD40 on the parts seems dirtiest/rustiest... basically points where your leafs first make contact. I used the straw spray nozzle to blow all the dirt/rust away. Then I jumped on the bed a few times to work it in to the gaps.
    I think it worked on mine due to WD-40s rust removing ability. Like I said, the noise hasn't come back in a year.
  10. Mar 28, 2010 at 12:32 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Do you drive off road much?
  11. Mar 28, 2010 at 1:50 PM
    tacomamodboy
    tacomamodboy Member
    annapolis md
    09 trd off road
    Tube steps
    i had the same problem it went away in less than a week on its own it mainly form dirt
  12. Mar 28, 2010 at 4:29 PM
    Tyler_G13
    Tyler
    Texas
    well i cleaned them with water, and put LPS 1 on them and the problem is gone
  13. Mar 28, 2010 at 4:31 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
  14. Mar 28, 2010 at 4:44 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Jack up the truck(To give your self more room) then use a long screw driver or pry bar to spread the leafs apart. Remove the silencer pads(at the end of each leaf) 4 per a side iirc. clean them off and clean where you removed the pads from. Lube the pads up really well with grease from a stick what would go in a grease gun. I also lube where I put the pads back using popsicle sticks just to be certain I had everything covered. Then put the silencer pads back in the whole and make sure the seat properly. If not then you'll notice a gap between the leafs. Remove the screwdriver or pry bar. Repeat for all 8 and you should be squeak free.
  15. Mar 28, 2010 at 6:49 PM
    NAYo2002
    Great Falls, MT
    Don't hit too many trails but I do live in Montana. There are more unpaved dirt roads then there are paved roads.
