Squeaky
Discussion in 'Suspension' started by KEG87, Apr 27, 2009.
  1. Apr 27, 2009 at 3:15 PM
    KEG87
    KEG87 [OP] Its Not Just A Truck
    Arkansas
    TSS
    Blackedout headlights, Throttle body spacer, Stage 6 Mindblower Performance Programmer, Leds TailLights, Bed Cover,
    tryin to figure out why the ass end of my 06 tacoma prerunner is squeakin so damn bad anybody have any insight
  2. Apr 27, 2009 at 3:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    have you went mudding recently???
    maybe pressure wash the springs real good and spray some dry moly lube in all the openings......should take care of the squeak if its the springs, and at least it'll eliminate what the cause is.
  3. Apr 27, 2009 at 3:43 PM
    KEG87
    Arkansas
    TSS
    nope no mudding at all and i wash under there about once a month and i also sprayed wd40 on the spring but no help
  4. Apr 27, 2009 at 3:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    wd-40 is kinda a bad idea, just so you know. it actually attracts dust and dirt. i'd try spraying it off real good again, and get a good moly lube for it....spray between each leaf and see what happens.
  5. Apr 27, 2009 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What He said ^^^^^^^^^^^^^^
  6. Apr 27, 2009 at 3:49 PM
    KEG87
    Arkansas
    TSS
    yeah i sprayed it off and im going to apply some graphite or maybe some lithium grease didnt consider moly
  7. Apr 27, 2009 at 3:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    lithium will do pretty good........i just like moly because it dries good, makes a barrier, and repels dirt and dust.
  8. Apr 27, 2009 at 3:55 PM
    KEG87
    Arkansas
    TSS
    i will prolly try it i have found a leaf spring silencer kit but i will prolly have to go to dealer to order it
  9. Apr 27, 2009 at 3:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    all that is is probably new plastic like pads to go in the springs....may help out tho. i'd still keep them sprayed down,even if i did get the silencer kit...it would cut down on dirt getting between the springs.
  10. Apr 27, 2009 at 4:15 PM
    KEG87
    Arkansas
    TSS
  11. Apr 27, 2009 at 4:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    they may have a type of it there.....or at a tractor supply or lowes/home depot.
  12. Apr 27, 2009 at 6:00 PM
    yamahamod
    yamahamod Active Member
    Korey
    Colorado
    06 Tacoma SC w/total chaos & King shocks
    My front end squeeks. So I just used my motor cycle chain lube and it works great. I believe it was the stabalizer bar where it goes thru the metal and rubber mounts at the end of the frame.
    You can see them in the picture on the far right side.
    I know yours is in the back but maybe it will spark an idea of what the problem might be on yours.
