Squeal sound coming from UNDER the truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pr3runnerTaco, Mar 9, 2018.
  1. Mar 9, 2018 at 2:29 PM
    Pr3runnerTaco
    Pr3runnerTaco [OP] Member
    Georgia
    2012 Tacoma Prerunner 4cyl DCSB
    Plasti-dipped badges|Flow-master muffler | otherwise still stock (not for long)
    Long time lurker, first time poster, but for a while i have had this sort of squeal sound coming from under the truck and near the passenger side. I noticed it awhile back at a drive through window but it didn't bother me that much. Couple months later, its starting to annoy the crap out of me because i hear it every time i am idling and near a wall. It seems to only do it when its warmed up. The sound is more noticeable when the A/C is on as well. I have crawled under and the sound seems to be coming near the cat and around the manifold. I've included videos that showcase the noise and where i believe its coming from. If someone knows what this is and there is a thread already created please provide a link as i have yet to find someone who has the same sound and general location of said sound. 2012 prerunner 4cyl with 70,000 miles.
    http://youtu.be/emRY8InMY_o
    Could it be as simple as the spring loaded bolts need tightening?
  2. Mar 9, 2018 at 2:45 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
  3. Mar 9, 2018 at 2:48 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Or the power steering pump might be low on fluid
  4. Mar 9, 2018 at 2:49 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Sounds like a bearing to me.
  5. Mar 9, 2018 at 2:51 PM
    lynlan1819
    Tacoma
    Lifted
    You will have too get under the truck when its running too trace the problem.
  6. Mar 9, 2018 at 3:06 PM
    Pr3runnerTaco
    Georgia
    Just replaced the belt a couple hours ago and there was no change in sound
    Its possible, i did spin one and it had some slight resistance to where it would only spin a second or 2 after spinning it
    It was running in the video and the sound seemed to originate from that location i just couldn't pin point it due to other noises.
    Ill check it
  7. Mar 9, 2018 at 3:15 PM
    Pr3runnerTaco
    Georgia
    Checked it and its 3/4 the way to hot which seems right since i just got finished test driving to see if the sound went away after a new belt about 1-2 hours ago
  8. Mar 9, 2018 at 4:23 PM
    Pr3runnerTaco
    Georgia
    1 idler pulley spins more freely than the other 2 but there is no sound and all of them have the same amount of wiggle
  9. Mar 9, 2018 at 5:11 PM
    Pr3runnerTaco
    Georgia
  10. Mar 9, 2018 at 6:41 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Idler bearing or belt tensioner pulley it sounds like
    Nalex likes this.
  11. Mar 9, 2018 at 8:03 PM
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
  12. Apr 7, 2018 at 2:15 AM
    Pr3runnerTaco
    Georgia
    Revisiting the problem, i got bored and dropped the skid plate to get a better look at the tensioner pulley while it was running. http://www.youtube.com/watch?v=VBtatMHpcrw Could this make the noise i am experiencing. Generally i would associate a bad bearing to be a more of a metal grinding on metal sound and not a high pitch whistle/squeaking sound. I read somewhere you can just take off the pulley on the tensioner and not replace the whole thing. Would a Gates 36173 work?
  13. Apr 7, 2018 at 4:23 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    My hearing must be worse than I thought. I don’t hear anything unusual in all the videos.
  14. Apr 7, 2018 at 8:13 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    @Pr3runnerTaco take the belt off and try to "wobble" the idler pulley like you were testing for a bad wheel bearing (push/pull top and bottom). If there is ANY play in it then it is probably bad. If you've gone through deep water recently that could be why (it was for me). The bearing shouldn't really make any noise and should have a good resistance to spinning since it's packed with grease. I have a bad one in the garage if you're interested to hear what it sounds like.
    To be honest, kinda sounds like a tiny exhaust leak in the first vid.
  15. Apr 7, 2018 at 1:49 PM
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    You auto or stick? If standard, push clutch in and see if it goes away. If it does, throw out bearing.
    Auto, take belt off and start it. Just for a sec. Goes away, you know it's in there.
  16. Apr 7, 2018 at 6:15 PM
    Pr3runnerTaco
    Georgia
    I have made a discovery just now. I parked with the passenger side near a wall and pressed in the emergency brake and slowly revved it to 1500 while in D and the whistle grew louder as RPM increased, any higher and the engine noise took over.
    Its an auto
  17. Apr 7, 2018 at 6:21 PM
    NeonHeights
    NeonHeights Well-Known Member
    Ive had the same sound for months. Only comes on in the morning when the truck is cold and just starts up. I believe its a bad bearing/pulley. Its definitely coming from the belt area
    I also had another loud high pitched squeak as well when driving/idling which turned out to be an extremely small exhaust leak at one of the flanges past the CAT. It would only happen at super random moments like idling at a stop light, then would go away entirely when I took off, only to return again at like 45km/h then go away again 5 seconds later.
  18. Apr 7, 2018 at 6:50 PM
    Pr3runnerTaco
    Georgia
    ill look around there in the morning and see if i can see anything
  19. Apr 7, 2018 at 8:31 PM
    NeonHeights
    I only figured out it was my exhaust because I tried all other options. I tightened down a few bolts on my exhaust that came loose and it went away.
  20. Apr 12, 2018 at 5:34 PM
    Pr3runnerTaco
    Georgia
    Bolts on the exhaust that i could get to are tight to the point i couldn't turn them and didn't see any pin holes on the pipe and from what i could see the headers looked ok. To add to the list ive noticed that when the compressor kicks on the sound either starts or is amplified to the point i can hear it. Just to add that to the list of possibilities.
