Squeal sound coming from UNDER the truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pr3runnerTaco, Mar 9, 2018.
  1. May 1, 2018 at 5:25 PM
    Pr3runnerTaco
    Pr3runnerTaco [OP] Member
    Georgia
    2012 Tacoma Prerunner 4cyl DCSB
    Plasti-dipped badges|Flow-master muffler | otherwise still stock (not for long)
    I have narrowed it down to the exhaust. When i push up on this rubber hanger the noise stops. Now on to whether its the hanger or something else.
  2. May 1, 2018 at 5:59 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Try spraying the rubber hanger with some wd-40 and see if it quits.
  3. Mar 23, 2025 at 4:17 AM
    pumpwrapper
    pumpwrapper New Member
    josh
    2017 tacoma Sr 2.7 5 speed access cab
    cold air intake
    Old thread but I have the same issue. Mine is exhaust related and at the same area. It is not the belt or an alternator even though it seems to happen when electrical things are turned on such as brake lights, headlights etc. Advance auto scan tool will tell you that it reads low voltage but it is normal for the 3rd gen 2.7 alternator which costs $500. That is a rabbit hole you want to avoid. It's the exhaust. Hope this helps someone in the future with this incredibly hard to find issue.
  4. Jul 25, 2025 at 5:21 AM
    Tacoma312
    Tacoma312 New Member
    Avion
    2013 Toyota Tacoma 2.7 I4
    Hello I have a 2013 2.7 I4 red pick up I’m having the same issues at the moment I have 100,500 on the clock. But that sounds only kicks on for me when I’ve driven the car for a certain period of time it doesn’t make the noise when it’s first started only after around 15-20 mins of driving. It isn’t the belts or pulleys because when I check they’re quiet not a chirp from them. Could it be an exhaust related issue. The sound is from the passenger side of the car. Sounds close to the catalytic converter.
  5. Jul 25, 2025 at 6:15 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  6. Jul 25, 2025 at 6:33 AM
    Tacoma312
    Avion
    Did you ever find the issue ? Just so I know what to look out for
