Squeal sound from left side of belt drive area
Discussion in '1st Gen. Tacomas (1995-2004)' started by maximilian55, Aug 20, 2014.
  1. Aug 20, 2014 at 10:33 PM
    maximilian55
    maximilian55 [OP] Well-Known Member
    max
    washington
    95.5 Tacoma 3.4l
    So today I replaced a bunch of different parts on my truck (2.7l). Thermostat, Water Pump, All 3 belts, Rad hose, Oil. I finished and took it out on test drive, and everything felt fine. However when I pulled in to my driveway, I heard a weird squealing sound.
    I popped the hood and heard it coming from left side (passenger) side of the engine bay in the very front. near the furthest left belt. The squeal kept a constant pitch, and was fairly high. However I would hear a very distinct click sound, like a camera, and then the squeal would stop for awhile. and then return, click then stop, and return again. I could only hear the squeal while I was at Idle, however my muffler is fairly loud so it could happen while i was in gear too.
    If anyone has any suggestions that would be greatly appreciated. It could very well be a part of my truck going out. She is just shy of 300,000 miles, and everything is stock in the engine bay besides what i replaced today.
    Also one of the pulleys has a slight slight wobble to it. Im sure I just need to tighten the lock nut on it. But if it doesnt fix itself, how concerned should I be?
    I appreciate any help
  2. Aug 20, 2014 at 10:36 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The click sound could be the A/C compressor's clutch engaging and dis-engaging. I bet that belt is a bit loose, and slips a bit, when the clutch engages the compressor, and increases the load on the belt.
