Squeal when engine is under load?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lightsped, Apr 14, 2015.
  1. Apr 14, 2015 at 1:19 AM
    Lightsped
    Lightsped [OP] Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    I hear what appears to be a belt squeal as I let my clutch out and start to accelerate gently. This only happens when the truck is starting off on a slight uphill with very low rpms. The squeal just last as long as the rpms are low or the engine is under load. Truck is a 4 cylinder with 60k miles. It also may be my imagination, but I hear the exact same squeal or chirp as the truck goes over small bumps in the road. It is just a very brief chirping sound.
    Will the serpentine belt be going out this soon? Is it an adjustment issue? Any ideas? Thanks
  2. Jun 21, 2015 at 2:01 AM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    I think I may have the exact same problem. Chirpy cricket noise occurs during acceleration from a stop under light loads at rpms near idle, like when parking or moving up a hill. When in neutral, pressing in the clutch does not produce the noise. Also while in neutral, reving the engine does not produce the noise either. I just hit 60K last week.
    Could it be the TO bearing?
  3. Jun 21, 2015 at 11:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Idler pulley going bad?
    If you press the clutch in does the noise lessen or go away?
  4. Jun 21, 2015 at 11:53 AM
    Taco Pete626
    Peter
    Southern California
    Noise only occurs when lightly accelerating from a stop (like in a parking lot situation) and at low rpms while letting out the clutch in 1st gear. If I really rev the engine (and risk burning the clutch) i do not get the noise. Noise is most prevalent when keeping the clutch in the friction zone and barely applying any throttle. It mostly occurs once the engine is warmed up. Other than that, while normal driving or idling, I do not hear it.
  5. Jun 21, 2015 at 11:55 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Could be your Throw out bearing...
    I've heard a bad pulley will whine louder as you accelerate.
  6. Jun 25, 2015 at 6:28 PM
    Taco Pete626
    Peter
    Southern California
    The noise has been bugging me for some time now and after reading some stuff from the other Tacoma forums, I think it's just the clutch making noise as it slips. Much like how a brake rotor and pads make noise under certain conditions. It does happen much more often after driving in stop and go traffic, so I believe maybe heat has something to do with it? Anywho, I've decided not to worry about it anymore and just enjoy driving my truck.
  7. Jun 25, 2015 at 7:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    T.O.B.
