Squeal when pressing gas???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scenekyd, Jan 1, 2014.
  1. Jan 1, 2014 at 11:14 AM
    Scenekyd
    Scenekyd [OP] Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    I need help pin pointing where the squeal is coming from. When I am going down the road above 35 I press the gas about 1/4 and it makes a annoying squeal. As I press the gas harder it goes away. It has done it 3 nights coming home from work. I was thinking power steering belt/pump. Someone told me the flywheel. I don't know. Any help would be great.
    Thanks in advance.
    Jay
  2. Jan 1, 2014 at 11:16 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    are you manual or automatic? Sounds more like a belt either needs to be tightened slightly or needs replacing though.
  3. Jan 1, 2014 at 12:19 PM
    Scenekyd
    Jay
    Hendersonville, NC
    Manual. Ive noticed it happens when it gets warmed up and is really cold.
  4. Jan 1, 2014 at 12:26 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    S/C kicking in
  5. Jan 1, 2014 at 12:28 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I would check your belts
  6. Jan 1, 2014 at 12:29 PM
    Scenekyd
    Jay
    Hendersonville, NC
    ? That's to Zaraki
  7. Jan 1, 2014 at 12:44 PM
    oldracer
    oldracer Well-Known Member
    I would be looking at the belt or belts; whatever your engine has. Certainly sounds like a loose or worn belt.
    oldracer
  8. Jan 1, 2014 at 12:46 PM
    Scenekyd
    Jay
    Hendersonville, NC
    That's what I am hoping it is. Just figured I would ask for second opinions before I went and spent money. Thanks everyone. If you still have suggestions. Post em. Thanks
    Jay
  9. Jan 1, 2014 at 4:29 PM
    2000GTacoma
    Snow Hill NC
    Pop the hood and grab all the belts. Should be able to move about a 1/2" either way.
  10. Jan 2, 2014 at 6:04 AM
    5lugger95
    5lugger95 Well-Known Member
    Sounds like an alternator belt, mine does this from time to time especially if i go off-road hard. Pretty easy fix, its a 12mm tension bolt to tightin up mine.
