Squeal while coasting at 25 mph plus, hit the gas it’s gone ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Valleykid1978, Nov 24, 2018.
  1. Nov 24, 2018 at 6:39 PM
    Valleykid1978
    Valleykid1978 [OP] Member
    Ray
    2003 Tocoma 2wd
    None
    Hey guys, need some help with 03 auto Tacoma 2wd 2.7 mysteries squeal while coasting, 25 mph or greater it squeals and as soon as you give it gas it’s gone. Changed all the belts and there tite and we’ve eliminated the belts. Just spinning my wheels guys and would appreciate some help or even a shot in the right direction am green.
  2. Nov 24, 2018 at 6:48 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    sounds like a ujoint
  3. Nov 24, 2018 at 6:49 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    I had a similar issue for a couple years. Thought it was belts, then idler pulley. Mine would only happen during cold weather after startup or any extended drive 2+ hours. Same thing mainly while coasting or around 2100 rpm but would go away if you gave it some more gas. Greased all the zerks on my driveshaft and haven't heard it since.
  4. Nov 24, 2018 at 6:51 PM
    Valleykid1978
    Ray
    2003 Tocoma 2wd
    None
    You think that could be it ? Ok I will give that a shot tomorrow morning. Really frustrating noise. I’ve read some post on here and am not the only one with this problem. I really appreciate your time and thank you.
  5. Nov 24, 2018 at 6:53 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I had it, but i had completely sheared my ujoint. I had to have a new one put in.
  6. Nov 24, 2018 at 6:55 PM
    Valleykid1978
    Ray
    2003 Tocoma 2wd
    None
    I will look in to that and another member mentioned greasing all my zerks on the drive shaft.
  7. Nov 24, 2018 at 6:57 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Well, bring your grease gun, while you are under there you will be able to tell if you sheared on or not. Sounds like a plan.
  8. Nov 24, 2018 at 6:59 PM
    Valleykid1978
    Ray
    2003 Tocoma 2wd
    None
    Thank you guys I really appreciate your guys is time. I’ve been spinning my wheels looking for some answers and I got some. Thanks again. Good night and I’ll be back tomorrow with an update
  9. Nov 24, 2018 at 7:19 PM
    1997tacomav6
    Denver
    Is the sound coming from the engine area or under the truck??
  10. Nov 25, 2018 at 12:37 AM
    RonJon31
    RonJon31 Well-Known Member
    Ronnie
    Alaska
    04 Single Cab Tacoma PreRunner
    5100s 265/75/16 Wildpeaks
    Had this exact problem, took the driveshaft off and cleaned up and greased the spline and never heard it again. This was after greasing the ujoint zerks and the problem persisted
  11. Nov 25, 2018 at 9:38 PM
    KDT
    KDT Well-Known Member
    Karl
    Phoenix, Finally Out Of Boston
    04 TRD
    If it happens while coasting but not while accelerating, it is probably the drive shaft carrier bearing.
    MacGyvR likes this.
  12. Nov 26, 2018 at 4:38 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    If the u-joint is making a "noise",,, squeak, or whatever,, it's to late, their dry and scarred, replace them.
  13. Nov 26, 2018 at 3:50 PM
    beeballman
    beeballman Active Member
    This could be the source of my squeak as well. I thought it was belts but noticed it was coming from under the truck and not the engine bay. I will have this checked out.
  14. Nov 27, 2018 at 10:33 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Random, because it would happen in park?
