Squeal/Whistle
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrosebr, Nov 3, 2010.
  1. Nov 3, 2010 at 8:21 PM
    rrosebr
    rrosebr [OP] Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    I have a high pitched whistle that I start hearing around 45-55 mph. I have pressed on the windshield (heard this may help) with no change in the sound. It sounds like its coming from the front of the truck and it air flow related. Any hints? Thanks in advance
  2. Nov 3, 2010 at 8:24 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    Try looking for anything in the body work that isn't in place the way it should be. Could be something bigger like a gap in the plastic molding at the base of the windshield, or something smaller like the rubber gasket around the door. Something else to think about is that sound can get tricky in a small cabin like the Tacoma's. You might hear the noise coming from in front of you when the source is behind you. Have you checked to make sure the small backseat windows are latched down?
    I hope this helps.
  3. Nov 3, 2010 at 8:33 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have a fairly low pitched whistle that I believe is coming from my deck plate... at least that's what I think. I just heard it after I did the mod. Do you have a deck plate?
  4. Nov 3, 2010 at 10:51 PM
    rrosebr
    Drew
    Blacksburg, VA
    Nope
  5. Nov 4, 2010 at 4:22 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    there is problably a hole or a leak in the molding around your windshield or one of the windows. also some wiper blades can make a whistling sound because of the holes in the design of them.
