Squealing and clanking sounds at full turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Nov 15, 2016.
  1. Nov 15, 2016 at 9:01 AM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I cant seem to pinpoint where exactly where the sounds come from, but likely the front left suspension. When making a tight right turn in a parking lot, there would be a screeching sound and metal clanking sound. It doesn't happwn if I crawl really slow. I checked the suspension at full lock and don't see anything rubbing. Seems like I need to turn fast enough to compress the suspension on one side to cause the noise.
    I'm on 2.5" lift with TC uniball UCA's.
    Any idea what caused this?
  2. Sep 30, 2019 at 10:30 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    did you ever find out whats causing the shreek mines doing this when making tight turns in parking lots or sweeping turns, I thought it could be the serpentine belt but im not sure
  3. Sep 30, 2019 at 10:45 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    My tires squeal in certain parking lots/ garages. No clanking sounds though.
  4. Sep 30, 2019 at 11:08 AM
    BillsSR5
    bill
    2014 SR5
    yes exactly my tires seem to be sqealing making these turns and they are also far beyond worn out so im assuming its them but wasn't quite sure because the sqeal is really bad, im looking into some new tires so hopefully they don't make the noise, im hoping
  5. Sep 30, 2019 at 11:59 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check your power steering fluid level,and your fan belt.
    BillsSR5[QUOTED] likes this.
  6. Sep 30, 2019 at 2:19 PM
    BillsSR5
    bill
    2014 SR5
    power steering fluid new,changed regularly, serpentine belt original 114k miles
