Squealing in neutral that goes away when clutch is engaged?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Feb 13, 2022.
  1. Feb 13, 2022 at 1:26 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Any Idea what causes this?
    I also have what feels like a couple inches of freeplay on the way down before the clutch engages.
    Password is TW
  2. Feb 13, 2022 at 1:28 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Your video is private but my educated assumption is your release bearing is making partial contact and the bearing is worn out.
    Pretty typical, prepare for a clutch job and consider the URD quill repair sleeve.
    Lil Puke and Jacked Burton[OP] like this.
  3. Feb 13, 2022 at 1:35 PM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    There are some YouTube’s and Google-able tests that might get you narrowed in on what’s going on. Anything from tranny input shaft bearing, to pilot bearing, or throw out bearing. See if you can make your video public and you’ll start getting some good answers!
    Jacked Burton[OP] likes this.
  4. Feb 13, 2022 at 1:36 PM
    Jacked Burton
    Password is TW
    That sucks but I appreciate your quick response.
    Second day I got it back in 2018 I had the clutch fail and had it done.
    I know they just resurfaced the plate when doing so (about 40k miles ago.
    What setup would you recommend I purchase for my mine?
    I'm talking about me walking into my mechanic with a box of parts,seals,lubricants.
    All they have to do is install it.
    Thanks brother.
    Truck is 2wd if that narrows anything down.
    I also just had brake fluid flushed to Motul dot 5.1 and all new braided stainless hoses on each corner.
    Don't remember this squeal being noticeable before I had that done friday.
  5. Feb 13, 2022 at 1:55 PM
    Key-Rei
    Key
    Florida
    Suppose it depends on what you really want to do with it, I mean it's hard to beat oem but it is a little bit more expensive, I've got a urd stage 2 in my truck I'm reasonably satisfied with it though it seems to be a little stiff.
  6. Feb 13, 2022 at 2:16 PM
    Lil Puke
    Oregon
    ‘99 Taco
    On your truck, do the clutch and brake rely on the same reservoir? Could be the new fluid is hard on the internals of the hydraulic assembly for the clutch.
  7. Feb 13, 2022 at 3:04 PM
    Jacked Burton
    I had to remove the shifter and pour a completely different type of fluid(Ultra1Plus 75w-90 GL-5) in when doing the Transfulid,than what I put in the brakes (Motul 5.1)the other day.
  8. Feb 13, 2022 at 3:06 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    See people. This is why you shouldn't get engaged.
  9. Feb 14, 2022 at 1:27 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    What does the fluid level look like in your brake reservoir? Is the pedal spungee? Could be air in the lines.
    You don't have to remove your shifter for a manual xmission fill... there is a fill plug above the drain plug.
    Check out a slave-cylinder rebuild kit. Helped with my clutch engagement and the noise of the TOB.
    Lil Puke likes this.
