Squealing noise on cold start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foozer, Apr 25, 2017.
  1. Apr 25, 2017 at 8:53 AM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    2012 trd sport dcsb, 54k miles, supercharged at 30k miles.
    So recently it's been colder than usual and really rainy, and the last couple of days when I cold start the truck I get this squealing noise for probably 5 minutes or so. I have gotten the squealing before during the winter when it was really cold, but it would go away after 10-30 seconds.
    I am wondering if anyone else has had issues with this and if it is time to replace the serpentine belt or supercharger belt.
    Any comments and thoughts are appreciated, thanks!
  2. Apr 25, 2017 at 9:01 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Accessory belt?
  3. Apr 25, 2017 at 3:03 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Belt. If you have more than one belt, spray one with some belt dressing and see if the sound goes away. If it doesn't try the other belt.
    Foozer[OP] likes this.
  4. Apr 25, 2017 at 3:33 PM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    X2. Could be power steering, but most likely a belt.
  5. Apr 25, 2017 at 3:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Belt dressing is a curse. I wouldn't do it.
    More than likely it is a belt. Remove the supercharger belt to isolate which one.
    JeffreyB, wilcam47 and Foozer[OP] like this.
  6. Apr 25, 2017 at 5:43 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What Jimmy said....
  7. Apr 25, 2017 at 10:11 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Awesome, got big o tire to change the supercharger belt and serpentine belt, parts and labor $150 bucks, so hopefully that fixes it!
  8. Apr 26, 2017 at 7:03 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Yup Go with Jimmyh . Change the belt. If still issues....
    - Check the Idler arm tension/pivot motion/bearing.
    - Since it was worse in the Winter - How old is the battery?? Extra battery charging after starting may cause an oldbelt to slip ...
    - When you get the Belt off - be sure to also check/spin the water pump, Generator, PSteering, etc. just to be sure the bearings seem OK.
    Lots of Luck TOO. Hopefully the Just the belt.
    Jimmyh likes this.
  9. Apr 26, 2017 at 7:13 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Thanks. I just replaced the battery a little over a year ago. I have my fingers crossed it's just an old belt! I'll check out those other things too
  10. May 16, 2017 at 9:44 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    any update on this? This morning i had a little squealing (also cold start, but not cold out), couldnt tell if it was belt or pulley. Just started at lunch and it wasnt there. I always like to find these things before they become a real issue.
  11. May 16, 2017 at 9:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    rev it up and if it goes away its prob your belt. I too advise against using belt dressing, typically if its a belt squealing problem it prob needs replaced.
  12. May 16, 2017 at 9:59 AM
    ejl923
    Eric
    Western Mass
    does pulley squealing go away, or usually stick around?
  13. May 17, 2017 at 6:58 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Update: Went to big o tire and had both the supercharger belt and the serpentine belt changed ($140 total). All noises are now gone. Both belts were pretty worn (SC belt had about 20,500 miles on it, serpentine had 55,000 miles).
  14. May 17, 2017 at 7:19 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Is changing belts something a DIY person could do?
  15. May 17, 2017 at 7:44 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Probably. I looked it up on the forums once (for the SC belt) and it looked pretty complicated and time consuming. So I bought the belt from Toyota and took it to big O and they charged me 30 minutes of labor to do it ($40). The serpentine was $100, that included the belt and install labor. So for $40 bucks I think it's worth having someone else do it in a shop.
    TacomaMike37 likes this.
  16. May 17, 2017 at 10:12 AM
    TacomaMike37
    13' DCLB MGM
    Yeah for $40 , a no brainer for sure.
  17. May 17, 2017 at 10:23 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Serpentine belt isn't hard to change yourself. I paid $18 for the belt and did it myself, took 15 minutes. There is a diy sticky on the forum
  18. May 17, 2017 at 10:36 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why is it bad?
  19. May 17, 2017 at 12:58 PM
    lynlan1819
    Tacoma
    Lifted
    Because all you are doing is putting a band-aid on the problem instead of solving the problem.
  20. May 17, 2017 at 5:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Belt dressing was fine when it was used on V Type Belts as that is what it is designed for. It is messy and for a serpentine belt it is basically useless with short lived results if any.
    CurtB likes this.
