Squealing or squeaky noise when I stop at a red light/stop sign/etc. When I start to take off
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zonakid, Dec 20, 2017.
  1. Dec 20, 2017 at 3:52 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    2002 Toyota Tacoma Pre Runner
    So I got my transmission rebuild at 170000 on November 23 2017 everything was going good then I would say 2 or 3 weeks later I start hearing this sound and no it doesn’t make this sounds when I turn my wheel all the way to the right or left but I do know that the sound is not as loud when I go to make a turn. I know the pervious owner before me replaced the timing belt at 75000 miles and I’m almost coming up on 100000 miles on that belt I don’t know if it could be the timing belt going out soon or not. I drive a 2002 Toyota Tacoma Prerunner crew cab 2wd 3.4L V6. If anyone has ran into this problem or knows what it might be I really would appreciate it I can’t stand when I hear weird noise from my truck!
  2. Dec 20, 2017 at 4:57 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Maybe a brake dragging? Where is the sound coming from? Front? Rear? Got a video?
  3. Dec 20, 2017 at 7:03 PM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    Exhaust shield or mounts squeaking? Had that on a Sienna, it would squeak when stopping and when taking off from a stop. Turned out that if you got underneath it and shoved on the exhaust it would make that same noise. Might look at that.
  4. Dec 20, 2017 at 10:24 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    Front of the truck
  5. Dec 20, 2017 at 10:33 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    I’ll look into it hopefully that might be it
  6. Dec 21, 2017 at 5:19 AM
    01GreenTacoma
    Have you checked the brake pads?
  7. Dec 21, 2017 at 7:09 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    suggested thread topic change:
    "squeaking/squealing noise when starting from a stop"
    first you have to determine if it's a "squeak" or a "squeal"
    squeak could be suspension or exhaust related (moving slightly)
    squeal could be a belt or drive-line issue (anything from motor to wheels)
  8. Dec 21, 2017 at 2:41 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    No I haven’t but it doesn’t sound like my brakes are going out
  9. Dec 22, 2017 at 8:28 AM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    It sound like a brake caliper might be hung up. A piston that is not going back in all the way.
    Does your truck pull to one side when braking?
  10. Dec 22, 2017 at 8:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    No. They don't make noise, they just break.
  11. Dec 22, 2017 at 10:11 AM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    No it brakes perfectly fine
