Squealing radio
Discussion in 'Audio & Video' started by kingoffire86, Dec 26, 2022.
  1. Dec 26, 2022 at 9:14 AM
    kingoffire86
    kingoffire86 [OP] New Member
    Bryan
    2015 Toyota Tacoma TRD
    I have a 2015 Tacoma 4door. The radio will be working fine then it will start making a squealing noise from what I think is the passenger side front door. I have turned the radio off then turned it back on 30- 1 hr later and it’s fine. Anyone else have this happen.
  2. Dec 26, 2022 at 11:49 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Does the squealing change pitch with RPM?
  3. Dec 26, 2022 at 11:59 AM
    kingoffire86
    Bryan
    No.
    I drove 9 hours to FL. And never messed up. The next day drove 5 minutes and it started. The noise will be there with music playing and if left on the music will stop and that’s all you hear
    Helllloootsimo likes this.
  4. Dec 26, 2022 at 12:29 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Is it all the factory equipment?
    Next time, see if you can pinpoint which speaker(s).
    I had a similar issue and it turned out my window metal was grounding out against the speaker, but mine was all aftermarket stuff and rewired from what the original was.
  5. Dec 26, 2022 at 12:32 PM
    kingoffire86
    Bryan
    All factory.
  6. Dec 26, 2022 at 1:44 PM
    ABA180
    East Bridgewater MA
    It's possible a connector came loose. I'd take the panel off the door (guessing that's where your speakers are) once you isolate the place and make sure it's on there good.
    Otherwise, depending on the exact sound, you either have a bad speaker or the radio has a bad channel.
  7. Dec 27, 2022 at 5:47 AM
    kingoffire86
    Bryan
    Finally stopped and put my ear on the speaker but come to find out it’s coming from all the speakers. Any ideas
  8. Dec 27, 2022 at 6:11 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Power could be grounding out behind the radio somewhere, or as mentioned, the unit itself has gone bad. Reading, and kinda helping here, I’ve found that a lot of factory headunits start to go in the 7-8 year range. Having said that, I’d start with tracing the wires that you can behind, and see if there’s a break.
  9. Dec 27, 2022 at 11:31 AM
    ABA180
    East Bridgewater MA
    My surmise as well since it's not isolated to one speaker/side.
    ZMan2k2[QUOTED] likes this.
