Squealing sound, when taking off
Discussion in '1st Gen. Tacomas (1995-2004)' started by allred27, Jun 19, 2009.
  1. Jun 19, 2009 at 10:27 AM
    allred27
    allred27 [OP] Member
    There is a squealing sound coming from the rear of my truck when I start out from a dead stop it only happens for a second, then goes away when I reach 3-4 mph. It sounds kind of like tire squealing, but I'm starting out at a slow speed. Anybody know what this sound is?
    '96 Tacoma 2.7lit 4x4
    thanks
  2. Jun 19, 2009 at 12:28 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Stop burning out.....:D
  3. Jun 19, 2009 at 1:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    could be a bad wheel bearing, or something to do with your drive shaft.
  4. Jun 20, 2009 at 10:27 PM
    TX Tacoma
    TX Tacoma Fightin Texas Aggie
    Arlington, TX
    Possible causes could be wheel bearing, driveshaft pinion bearing, or u-joint. You could jack up the rear wheels and have someone put it in drive while you tried to locate the source. I'd definitely try that first before you take a shotgun approach and start replacing stuff. None of those jobs are minor endeavors. Good luck.
  5. Jun 22, 2009 at 9:24 AM
    allred27
    thanks for you help I'll jack it up and try and find out where it's coming from. I'll post what the cause is
  6. Jun 22, 2009 at 9:26 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    could also be a rock stuck in your breaks
